Old HP power transformers... need some wiring advice! - diyAudio
Old 5th May 2012, 08:33 PM   #1
Default Old HP power transformers... need some wiring advice!
Not sure if I'm making a double post now... but here goes:
I managed to salvage some PAECO power transformers from old HP voltage meters. I believe they all come from model 400D from the early 60's. Seems to be high quality ones - shielded and everything.
The thing is I'm not quite sure how to wire them for 230VAC. There are two 115V windings and instructions in the schematic (bottom of the PDF: http://www.mcmlv.org/Archive/TestEquipment/HP400.pdf). Pin 4+6? Or join 4+6 and then connect mains to 2 & 8? I have to admit I'm a little confused
Thanks!
Old 5th May 2012, 08:42 PM   #2
HollowState's Avatar
Join pins 4 & 6, then connect mains to pins 2 & 8 for 230 volts. This puts the two windings in series.
(remove jumpers from 2 & 4 and 6 & 8)
1944: 18 year olds storm the beach of Normandy into almost certain death.
2017: 18 year olds need a safe place because words hurt their feelings.
Need advice wiring a tweeter. Gojira Instruments and Amps 2 6th April 2010 02:06 AM
Wiring your own... (mumble)... transformers Lisandro_P Parts 24 30th March 2009 03:42 AM
Layout and wiring advice Nohabla Chip Amps 4 28th January 2009 12:46 PM
hp-8903B advice?? idealinnovat Equipment & Tools 14 5th September 2008 11:23 PM
Copyright 1999-2017 diyAudio
