I just finished replacing all the power and coupling caps and all the resistors on this and while it plays good and has bass the treble is just too high and sounds kinda "SCRATCHY" not smooth? I used metal foil coupling caps at .27uf just as the schematics called for? Should I have increased them to say .35uf?
Thanks as always for your time and thoughts folks
If you have replaced all the original paper capacitors with modern plastic dielectric types, the frequence response will be increased on the high end over what it was, And if you replaced the original carbon composition resistors with metal films, that exacerbates the problem. Somewhat less so for carbon films. It is not the numerical value, but the material "upgrade" that does it.
E-mail sentThe site doesn't show my email address. Email me through this site and I'll respond. That will give you my email address.
a 5Y3 will give you more B+ voltage.
Perhaps. But, at 125mA maximum with cap input, it doesn't have the current capability for four EL84s at full power.
You are absolutely correct. I wasn't thinking stereo. For some reason, I was thinking that this is a mono amp.
Scratch the 5Y3. 5AR4 would be a better choice.
Another advantage, the 5AR4 draws much less filament current.
- Tubes / Valves
- RCA RS177H just dosen't sound right! Caps?
