Help needed: hum noise in Eimac 250TL driven by 75TL Single End Amplifier - diyAudio
Old 3rd May 2012, 10:41 PM   #1
Default Help needed: hum noise in Eimac 250TL driven by 75TL Single End Amplifier
Old 4th May 2012, 06:26 PM   #2
Gluca is offline Gluca  Italy
Gluca's Avatar
that must be a seriuos amp. maybe filaments (AC or DC)? or bad ground wiring? power transformers polluting a too close OPT or other signal transformers?
Old 4th May 2012, 09:56 PM   #3
Does the amp hum when the input is grounded? If no then try another source since your generator may be causing the problem. If yes, then things get more interesting. Go through the amp and re-solder the all ground connections, input, output, especially if the output transformer output winding ground is bad you get all sorts of weirdness going on and all of the connection on all four tubes. Those tubes run very hot and cook solder joints until they get bad. As Gluca said check all wiring to make sure you don't have an A/C cable bundled in with signal wires. Remember to try other tubes.
Since this is a stereo amp I am guessing it has a common supply for both channels. So if the power supply has a problem it will effect both channels. Pull the power tubes and tape up any loose wires. Safety first! Both of those tubes can have very large voltages which will kill you if you are careless. Turn on the amp and scope the output of the power supply to see what the voltage is and at the plate of the driver. If you see A/C trash on the driver plate and at the power supply then pull the driver tube and check again. If the trash is still there then the problem is in the power supply. Work your way back through the power supply cap string by disconnecting each section until you get clean DC. If you see trash on the B+ of the driver only when the tube is in place try another tube. If you still have the hum then you may have to trace out a schematic to see how the tubes are set up. This is just best guess with no schematic.
Old 4th May 2012, 11:59 PM   #4
Yeah, I think this amp has some potential.
The filament of both tubes is DC.
Perhaps.
I am certain that the hum is generating from the 75TL (driver).
I replace the loading resistor for the 75TL from 20k to 40k.
The plate voltage decrease and also current draw. Under this condition, there is 370mV hum (down from 600mV) at the grid of the 250TL and also at the plate of 75TL.
Therefore, there is only 100mV hum at the OPT secondary.
Old 5th May 2012, 12:10 AM   #5
Andy,
There is hum with the input grounded.
I will look into what you mentioned.
Both 250TL and 75TL use the same power supply. There are resistors, 40k total, in series with 75TL plate.
250TL plate is 1300V
75TL plate is 700V
There is 370mV AC at the 75TL plate.
Old 5th May 2012, 12:26 AM   #6
kevinkr's Avatar
The voltages here are positively lethal, and we have no idea how much experience you have with tube gear (possibly not a lot) particularly with these voltages.
Please affirm that you understand how to work safely at these voltages. (If not please read the high voltage thread here)
How exactly have you determined this is 60Hz - did you use a scope with a proper HV probe? Are you sure this is not 120Hz ripple from a bad power supply filter capacitor?
Are you certain that the DC filament supply is free of ripple?
Changing the 20K to 40K is not the right thing to do long term, but seems to point at the plate supply to the 75TL as a possible culprit..
How about a few pictures and a schematic. Who built the amp?
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 5th May 2012, 12:35 AM   #7
Kevin,
Thank you for you concern.
I have a Fluke 87. It can measure the frequency of AC voltage.
Notice I have not measure the AC voltage of the 250TL plate.
A friend of mine built this amp.
Old 5th May 2012, 12:39 AM   #8
I make sure there is no voltage before touching the amp.
After I turned off and disconnected the amp, there is about 100V.
I drain the caps by connecting two Fluke 87 meters to the B+.
Also, I have a Fluke high voltage probe.
Old 5th May 2012, 12:41 AM   #9
I am not certain that the DC filament supply is free of ripple.
2A3 Single End Class A amplifier Musik007 Twin Audio 48 10th October 2015 02:57 PM
HELP: Eimac 75TL amp high frequency roll off HP8903B Tubes / Valves 71 30th April 2012 04:53 AM
6L6 class A single end amplifier Musik007 Twin Audio 33 28th April 2010 06:18 PM
Pure Class A Single End Amplifier Idea! Dxvideo Solid State 91 1st September 2008 11:54 AM
Copyright 1999-2017 diyAudio
