EZ80 Data Sheets, R-Lim and Max Cap - diyAudio
Old 3rd May 2012, 06:04 PM   #1
jamesdb is offline jamesdb  United States
Default EZ80 Data Sheets, R-Lim and Max Cap
Looking at data sheets for EZ80 (and EZ81) there are mentions of the tube needing a certain amount total of resistance on the anode, made up the transformer's resistance, plus addition of "limiting" resistors id needed. Is this needed only for capacitor input, not choke input supplies? That's the impression I got. Also is the max capacitance listed only for cap input supplies, that does not apply to C1 in a L1C1-L2C2 supply, is that correct also?
Old 3rd May 2012, 06:07 PM   #2
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Both yes. But have in mind that some part of this resistance is actually the xformer reactance (leakage plus primary resistances/inductances reflected into th primary, so teh effective resistance may be less than needed.
If anything can go wrong, it will.
If anything just cannot go wrong, it will anyway.
Old 4th May 2012, 02:41 AM   #3
Thanks Osvaldo!
Old 4th May 2012, 03:27 PM   #4
10.04
Data Sheets wdcw Tubes / Valves 1 23rd August 2010 02:12 PM
Where to find data sheets? Zap Tubes / Valves 4 20th November 2007 07:38 PM
M5238 data sheets??? Christer Parts 5 30th March 2003 05:07 PM
Copyright 1999-2017 diyAudio
