Quicksilver 8417 Power Supply Question
Old 3rd May 2012, 04:02 AM   #1
john65b is offline john65b  United States
john65b's Avatar
Default Quicksilver 8417 Power Supply Question
Hey all,
Looking into building a Quicksilver 8417 amp - but don't know what the Choke inductance / DCR is - Is it a 15H, 200ma??
Thanks in advance!!
I Speak Spanish to God, Italian to Women, French to Men, and German to My Horse. Charles V
Old 6th May 2012, 01:07 PM   #2
Burnedfingers is offline Burnedfingers  United States
Having owned a number of the mono block Quicksilvers I can tell you that they sound good. I will also tell you that you can purchase them off ebay cheaper than you can build a pair. Also, there are amplifiers that sound better than they do. So, why bother? The 8417 uses a 12aX7 as the VA and a 12au7/12bh7 as the phase splitter and the circuit is a copy of what Bogan first used in their commercial 70 volt PA amp. Downfalls of the 8417 is the bias circuit. It requires that you either re-design and build a different bias circuit like I did to give the capability of individual tube bias or use the circuit as designed and have to purchase matched output tubes.
Old 6th May 2012, 02:34 PM   #3
john65b's Avatar
Hey - Thanks Burned - I had a real 8417 and really liked it, but reluctantly sold it - it came to me with 6550's and no real mods that I could remember.
I have a nice pair of monoblock chassis, KT88's, 12AX7, 12BH7, a pair of 4300 60W Edcor OPT, and a pair of 350-0-350 250ma with 60v bias tap power trannies.
I got everything in order, except the Choke. I like the simplicity of the 8417 circuit. I also plan to drop the tube rectifiers in favor of the Diodes -similar to what you did years ago...not even the soft start tubes...
You have a schematic of something better with more or less same parts? I have not torn into the chassis, and have pairs of 6DJ8, 6H30, 6SL7, 6SN7, 6NP1, 12AT7, 12AU7, 5693, 5687, oh hell...don't want to get into Williamson types...something simple, great sounding..thought the 8417 would be a perfect build.
Besides, the ebay 8417 amps are a rarelty and commanding upwards of $750...
Old 6th May 2012, 03:50 PM   #4
Palustris is offline Palustris  United States
Palustris's Avatar
"350-0-350 250ma with 60v bias tap power trannies"
Well, with Edcor you have a choice of at least two suitable chokes based upon your power requirements:
CXC150-10H-300mA @ 72 ohms dcr
XC75-1.5H-250mA @ 17 ohms dcr
Your choice depends on what your budget is and if you want an ultra low dcr choke or not. You might even try two XC75-1.5H-250mA in series as CLCLC.
Old 7th May 2012, 12:57 AM   #5
I have a pair of bastard child 8417's that I converted to use 6550's. Some idiot replaced the original Quicksilver output transformers with Hammond. I re-did the bias circuit also and it sounds really good especially for what it is.
If it were me I think I would try the XC75 choke. I would use diodes and 5Ar4's on it. To me it just doesn't sound as good with straight diodes in the power supply.
Take a look at the mapletree driver board circuit. I has used that a number of times and in my opinion its a lot better than the original circuit. This winter I will gut the mono blocks again and change it over to a 6SJ7 VA with a 6SL7 long tail or a 6SJ7 VA with a 6SN7 long tail phase splitter.
Old 7th May 2012, 12:13 PM   #6
john65b's Avatar
I have looked at that circuit, while not as simple as the Quickie, it is a Mullard type design, which I have wanted to build for a long time...you feel its performance / Sound best the quickie 8417 w /KT88's? Pretty much same tranny (4300 ohm) and power supply requirements. I think I even have the 6SJ7's too.
Old 7th May 2012, 03:07 PM   #7
Palustris's Avatar
"change it over to a 6SJ7 VA with a 6SL7 long tail or a 6SJ7 VA with a 6SN7 long tail phase splitter."
That looks like a great circuit to me. The Dynamutt circuit from Classic Valve also looks interesting with a 6SL7 VA direct coupled to a 6SN7 LTP with a CCS in the tail.
Old 7th May 2012, 04:02 PM   #8
Mr. dB is offline Mr. dB  United States
Mr. dB's Avatar
Front end for the 8417 is essentially the same as a Dyna ST35 isn't it? Didn't the early ones even use 12DW7s?
Old 7th May 2012, 11:10 PM   #9
I know the 35 uses a 7247 front end and I don't know if they used something prior to that.
http://www.triodeel.com/8417.htm
The general circuit looks like it was borrowed piecemeal out of a Bogen MO-100 PA amp (not a bad place to start, actually). These amps have problems with output tube instability due to unnecessarily high grid circuit resistors on the 8417 tubes, and occasional arcing over of the 5AR4 rectifier tubes due to the input capacitor being 3 times the maximum size allowed according to the tube specifications. The manufacturer uses 1 each of 12AX7 and 12AU7 (or 12BH7) tubes, but only uses half of each tube, the other half just sits there and does nothing.
Old 8th May 2012, 01:11 AM   #10
Palustris's Avatar
I don't know who first used that front end but Altec used it for their A333A.
Edit: sorry I forgot the ST35 used a triode front end.
Quicksilver 8417 Power Supply QuestionHide this!Advertise here!
Quicksilver 8417 conversion Burnedfingers Tubes / Valves 25 18th December 2011 11:33 AM
Quicksilver 8417 question john65b Tubes / Valves 1 24th October 2008 08:40 PM
Quicksilver 8417 power supply caps? popeye4 Tubes / Valves 16 1st September 2005 11:10 AM
Quicksilver 8417 dreaded 42 Tubes / Valves 4 5th September 2003 12:14 AM
Quicksilver 8417 model changes Burnedfingers Tubes / Valves 3 12th April 2003 03:45 PM
Copyright ©1999-2017 diyAudio
