Old 8th May 2012, 10:29 AM   #11
That is a nice front end. I am partial to the 6SJ7 as the VA. I think that front end would sound much better than the stock 12AX7 12bh7 of the 8417.
Old 15th May 2012, 07:57 PM   #12
tympani1d's Avatar
Default QS 8417 --> Sweep Tube? How To?
Hello.
I know this is slightly off topic but as I do not often see QS 8417 questions asked..
Has anyone here mucked about to use sweep tubes in these? It seems a very good candidate for such a mod. Nice simple topology and should sound great, powerful, plus not require geek tweek fiddly stuff?
Second question, what bias current are people setting when they convert to the ¨Super¨ 6BG6GA (7027 innards), 6L6 (6P3C) variants?
I have just installed my last two matched Sylvania 8417´s. All four of my amps are modified to allow bias setting for the other tubes and I do have 4 matched quad sets of the 6BG6GA and the socket adapters..
But I have no idea what bias current to set.
Thank you.
I think; therefore will NOT be Politically Correct.
Old 16th May 2012, 10:40 AM   #13
The Super 6BG6GA's can easily run 50mA bias each without a problem. I've run them in my modified 8417 mono blocks. Pull out the 8417's and put them on the shelf for another day.
Old 16th May 2012, 05:45 PM   #14
tympani1d's Avatar
Thank you... I´ll give them a try.
Old 17th May 2012, 01:33 AM   #15
if you bias your amp,you have to matched the plate current of the two tube of each monoblock by at least 5% without exceeding the maximum allowable plate dissipation.
Quicksilver 8417 conversion Original Burnedfingers Tubes / Valves 25 18th December 2011 10:33 AM
Quicksilver 8417 question john65b Tubes / Valves 1 24th October 2008 07:40 PM
Quicksilver 8417 power supply caps? popeye4 Tubes / Valves 16 1st September 2005 10:10 AM
Quicksilver 8417 dreaded 42 Tubes / Valves 4 4th September 2003 11:14 PM
Quicksilver 8417 model changes Original Burnedfingers Tubes / Valves 3 12th April 2003 02:45 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
