Why a sudden distortion in treble of this SET amplifier? - diyAudio
Old 2nd May 2012, 10:19 PM   #1
Default Why a sudden distortion in treble of this SET amplifier?
I have had this very sophisticated SET amplifier with 520B valves on the output for a few years now; recently I noticed a unusual distortion between 5k and 12k that was not present before. Neither is the distortion in three other amps I have so I don't think it's related to the AC line. Nothing else change in the amp's sound that I could tell.
If it is a bad part in the amp, what are the first suspects? cap, resistor, tube?
Old 3rd May 2012, 12:29 AM   #2
Are you sure it is not the tubes.
I wish I could help try and post this ? on diytube.com
maybe those guys can help.
Old 3rd May 2012, 02:26 AM   #3
tim614 is offline tim614  United States
tim614's Avatar
power supply caps, im guessing.
i had the same thing happen to one of my amp, it turn out to be bad power supply caps.
Tim
" perfect imperfection "
Old 3rd May 2012, 02:28 AM   #4
tim614's Avatar
what brand is this amp?
Tim
Old 3rd May 2012, 06:17 AM   #5
I have tried different tubes and the problem persists.
The amp was made in Denmark by J. Nielsen. But the designer has no idea what could be the cause.
I also thought it could be the PS caps, especially considering the number of 150uF caps he uses in series for the B+ filtering. I think there are 24 of those caps in series... Checking that will be a major work.
Old 4th May 2012, 05:50 AM   #6
M Gregg is offline M Gregg  England
Just a thought,
Have you checked the bias of the O/P tubes? also bias voltage and B+ supply voltage + ripple? Can you direct us to a schematic it might be easier to give some more information..
M. Gregg
Old 4th May 2012, 06:00 AM   #7
I haven't. Can you tell me how to do that?
HP 339A Distortion Set cowboy99 Swap Meet 9 31st May 2014 05:27 AM
need help on treble distortion with my EAR834p phono bigpandahk Tubes / Valves 8 26th December 2010 02:54 PM
RADFORD - Low Distortion Measuring Set TomWaits Equipment & Tools 15 22nd November 2007 04:17 PM
simple guitar preamp with bass treble distortion garydmd Chip Amps 0 7th April 2007 03:27 AM
Iron set for Paraglow (2A3) SET amplifier Alain Favret Swap Meet 1 19th March 2004 06:23 AM
Copyright 1999-2017 diyAudio
