Hello All,
I am trying to learn up on some concepts before I take the plunge in building a small 1W amp. I have googled this question, but haven't come across a straight answer. Apologies if this is obvious, but this is a case where assumptions could be painful, so I will ask anyway and possibly help some future googler at the same time. There is much advice online about using an isolation transformer in designs, for safety, and to allow you to use test equipment easily, etc. However, in most amp designs online, there is only a power transformer at the front end. Am I correct in my surmise that these power transformers (e.g., 269EX) play the role of isolation transformer in these designs? It seems to me that they do indeed isolate the internal voltages from the line voltage, but at the same time (usually) step up voltages? In other words, one does not require both an isolation transformer AND a power transformer, for reasonable safety, correct? Am I further correct that the warnings about adding a true (1:1) isolation transformer are generally directed at people working with amps which are directly rectifying line power to make DC? Thank you. |
#2 |
You don't need an isolation transformer and a mains transformer. The mains transformer will isolate your equipment from the mains.
#3 | |
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Be careful.
LW1DSE |
#4 | |
Point taken though. Be careful with some commercial designs. |
#5 |
An isolation safety transformer has primary windings and secondary windings in two serarate chambers (also NOT wound on top of each other!) so in case the primary winding
Burns out it can't come in contact with the secondary winding. In most valve amps the windings are in one chamber, wound on top of each other, insulated by a layer of insulation Material and an earther copper screen. Te latter type is smaller and cheaper in comparison with a safety insulation transformer. Ceerio, Stef |
#6 |
Hi Kati. You are right, I´m referring to a general case, because some newbie can understand (wrong) that all transformer equipments are isolated, and not always is this the case.
LW1DSE |
#7 |
Another useful use of an isolation transformer is the "PC oscilloscope" using sound cards in personal computers. The PC sound card is not isolated from anything and it makes the use of the scope probe and ground wire quite dangerous. However, even using an isolation transformers on the PC, the sound card and PCI bus on the main board are subject to being blown up by a faulty circuit you are examining.
Really old TV's (1954) had one side of the electronic chassis connected to one side of the power line (western hemisphere) insulated from the metal case by cardboard. I was tickled many times by current in bare feet on Mother's 1954 Philco. So the direct connected to line televisions with SMPS were following an old and disrespected tradition. Thanks to Osvaldo for point out that they are still doing this.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300 Last edited by indianajo; 2nd May 2012 at 04:06 PM. |
#8 |
The bottom line is,
That any amp you build should have a mains transformer (Tx) unless you know what your doing with SMPS..The idea of isolation Transformer is to prevent direct connection to the mains supply under fault conditions...A mains Tx limits the fault current and helps protect you...without it (in the past) the chassis was connected to neutral which is at a lower potential..however if the mains plug was wired incorrectly then the live could be connected to chassis.. ..fault current is limited by the fuse, however it can draw as much as the supply will give for a fraction of a second before the fuse opens...not a good situation if your on the end of it..Remember that there will still be lethal voltages present on tube equipment and power supply caps can hold charge... A mains Tx does give seperation from mains supply but the definition of isolation is as above separate windings isolated from each other and earth so they must not short togeather under fault conditions a normal Tx can.. Also your tube supply will be earthed in some way and this is not separation of supply.. So fit a mains Tx and build in the normal way with correct earthing..So a standard mains Tx is OK...Unless you have some special reason for using an isolation Tx. Having said that don't use an auto transformer it does not have separate windings....You can use an isolation Tx if you can get the correct voltages and use it as a normal Tx with the earthing etc as in a normal amp..might cost more to buy.. Link: Untitled Regards M. Gregg
What is the sound of one hand clapping? Last edited by M Gregg; 2nd May 2012 at 04:34 PM. |
#9 |
I Ran A VCR/AUDIO Business For Over 16 Years (1986- 2003) and I always Used a Isolation Transformer and a Variac to service all my Units!!! When I took Electronics in High School Our Teacher told us,,, Better to be Isolated than electrocuted!! This proverb has Stuck with me to this Very Day!!! I always Believe Safety First,,,Sorry To Disagree with anyone here..What a Interesting Topic we have going here!!
#10 |
In the service business, you're powering up many units a day, all in unknown condition... so starting every test with isolation (and ideally a ground leakage test) is wise. I generally test unknown older equipment for insulation resistance using a cap tester before plugging it in. Often I find a failure due to a leaky capacitor from line to chassis - sometimes know as the "death cap" - which I will clip out before testing further.
Non-isolated circuits were common from the 1930s to 1960s, running directly off the power line line without a transformer. While (usually) safe when used as designed, they can dangerous to work on without the use of an isolation transfomrer. ANY modern power transformer has been tested for insulation breakdown from primary to secondary using at least 1000V AC. Those specifically designed for safety isolation may get higher test voltage, some as high as 3000V. But remember that the transformer isn't the only possible point of breakdown - I have seen broken fuseholders that caused shorts to the chassis, screws that dug into power wires, burned secondary wires that shorted to AC wiring... |
| Isolation Transformer Question | Skuker | Tubes / Valves | 8 | 30th November 2009 07:28 PM |
| Isolation Transformer Question | Captn Dave | Tubes / Valves | 6 | 28th April 2009 03:30 PM |
| Isolation Transformer question | Jack Torrance | Power Supplies | 7 | 2nd January 2007 08:37 AM |
