how do I determine what the bias voltage of the input tube is in this amp? MC20_L Schematic.jpg Do I simply measure the voltage between grid and cathode? The reason I'm wondering is that I have a Pure ipod dock connected to it and it outputs a 2v signal at full volume on the dock (my cd player outputs at 2v as well). When I have the dock turned up fully (as I have been doing to match the cd player so I don't have a huge difference when switching sources) the sound through the amp has harsher high frequencies than when it is turned much lower. The input sensitivity of the amp is .25v. I understand that if the positive peaks of the input signal exceed the bias voltage of the tube, they will be distorted...is this what's going on? Btw, I don't think it's a problem with the dock as the sound quality of both the cd player and the dock are indistinguishable to my ears when the dock is at max output (2v). |
#2 |
Yes, you can determine the bias for the input valve by measuring from cathode to ground. Where is your volume control? Bias is not the only issue, as you can get clipping at the anode too or at the output. You can't put a 2V signal into a 0.25V input.
#3 |
Sin Bin
Well, the circuit diagram says -56v at the input point (just to the left of the two top output tubes (EL34s).
Since the cathode resistor is only 10 ohms/ 5W to ground, and just for laughs assigning a plate current of 40 mA for each tube, gives us about a .4 volt drop on the cathode resistor. Further, the -56volts bias is stepped down a bit through the 50K pot(s), so it could wander anywhere from -56 to a voltage divided between the RP101 (50k ohm) and the R113 (33k ohm). 33/50 x 56 = 37 volts, so the range of bias possible seems 37 - 56 volts. A look at a datasheet for an EL34, combined with the High Voltage estimated to be produced by the powersupply, will give both an idea of the expected quiescent current and the ideal bias point. The power supply is marked as A.C. 320 v winding, so that times .9 = 290 volts D.C. applied through the transformer to the plates. Looks like there's a switch between Ultralinear and Triode modes, which at under 300 volts seems reasonable. The datasheet for an EL34 can be found here: http://www.datasheetarchive.com/EL34...tml#datasheets Here's a typical loadline chart: ![]() From this it looks like about -28 volts is ok for a 4k load and 300v supply... Here's a higher power/voltage version:
#4 |
Is this Yaqin schematic?
#5 |
The OP's question was about input bias, not output bias.
#6 |
Sin Bin
Doh!
The input section looks like an SSRP stack, so the top tube is self-biasing, determined by its cathode resistor and the quiescent current. The voltage across either R104 (1k5) or even R109 (33k) should allow a quick calculation of the current through the stack. From the stack current and the cathode resistor, you can calculate the bias-voltage. Since you are playing with high voltages, and to measure you must turn on the unit, USE THE ONE-HAND IN POCKET RULE, and be very careful with your probe! Make sure your feet are on a rubber mat, and your body can't touch any grounded metal on the bench. This looks like a job for someone experienced in HV measurement, as it is dangerous. The range of current can be estimated by simply looking at the tube data for a 6J1, and/or a few schematics or projects which use this tube! In any case, the bias can be closely predicted to a small range of values, without taking any risks. But from your symptoms, if you can get loudness from a different input without distortion, then the input impedance could simply be overloading the output of your music source. Why not try a buffer-preamp? Its unlikely to be a fault of the amp, but rather an impedance mismatch. Last edited by nazaroo; 2nd May 2012 at 12:03 PM. |
#7 | |
Another thing is that if you overload the input stage you have probably already overloaded the output stage as well. It is (or should be) common practice to design an amplifier with some headroom before the last stage.
Life is hard - Then you die. Last edited by jane; 2nd May 2012 at 02:07 PM. |
#8 | |||
Yes, this is the schematic for the ms-20l...it's not entirely correct though. Quote:
Really curious if I am actually exceeding the bias volatge with a 2v signal. |
#9 |
It is unlikely that a power amp is going to have its main clipping point at the input, except if a fault is present. We still haven't heard where the volume control is.
Just seen your latest post. Do you have a volume control? You can't just put a 2V signal into a 0.25V input on a power amp. At the least you need a 'passive preamp' i.e. a volume pot in a box. Last edited by DF96; 2nd May 2012 at 04:17 PM. Reason: extend |
#10 | |
That means the problem must lie elsewhere, doesn't it? |
| exceeding plate voltage of the output tube | mdm102 | Tubes / Valves | 6 | 29th August 2011 12:17 PM |
| A-75 Bias voltage | Zapped | Pass Labs | 15 | 18th February 2011 01:35 AM |
| Driver Bias and Voltage? | SGregory | Tubelab | 1 | 3rd January 2010 10:24 PM |
| Bias Voltage | AmpBuilder225 | Tubes / Valves | 4 | 17th March 2009 11:27 AM |
| bias voltage vs bias current | woodturner-fran | Tubes / Valves | 3 | 24th February 2007 11:24 PM |
