Old 1st May 2012, 11:26 PM   #11
grufti is offline grufti  United States
wombat
grufti's Avatar
The link worked for me just fine. That is one amazing design.
Originally Posted by TheGimp View Post
Wayback machine ..
http://web.archive.org/web/200905301...9_Abstract.pdf
I don't know if the link will last, but one can go to the wayback machine and insert the url in George's post and it will take you there.
Old 2nd May 2012, 01:49 AM   #12
Fenris is offline Fenris  United States
Broskie had an interesting Super Triode:
SuperTriodes & Inverted ES Speakers
I'm about 85% done building one, albiet with a few minor changes.
I just built another amp that has relatively straightforward tube topology, but uses tubes for voltage gain and a MOSFET as a current amplifying device, kind of like PowerDrive taken to the next level:
New amp: 13DE7 SE hybrid
Listen to the music through the stereo, not the stereo through the music.
Old 2nd May 2012, 06:37 AM   #13
Michael Koster's Avatar
Here are a few I have tried:
Another kind of hybrid
Spud-Assist: Totem-Pole Current-Mirror PP Hybrid
Schadeode
Most linear triode-strapped pentode
Class A2 Direct MOSFET Coupled SE
G1=G2/mu Scaled Drive Strawman Design
Old 2nd May 2012, 06:16 PM   #14
tubelab.com's Avatar
That minitron sounds like it is doing what some car amps do to keep cool yet have big output
I haven't kept up with the current state of the art in car amps, so I can't say, but my design is effectively a class H amp. There are three ways to make a high efficiency audio amp. Class D, class G and class H.
Big power with high efficiency can be obtained by using a fully digital implementation. This is offten called class D and is basically a large agile SMPS with a low pass filter on its output. The power supply voltage is varried at an audio rate and then the audio is recovered by low pass filtering. This offers the best efficiency. There can be problems with interaction between audio harmonics and the switching frequency and filtering issues, but modern implementations have become very good. TI has a "chip amp" that cranks out 600 Watts!
A class H amp has one or two (bipolar) power supply rails that are agile (modulated at an audio rate) and applied to a conventional (typically solid state) audio amplifier. The audio amp remains fully analog and if it is designed with good PSRR the implementation can be an excellent performer. This requires a conventional audio amp of good design and at least one complex power supply, so it can be quite complex. The efficiency is less than class D, but can come close.
A class G amp has a conventional audio amp and multiple sets of supply rails that come from conventional power supplies. The amp switches between sets of supply rails depending on instaneous demand. There is another variation that uses a pair of output transistors on each set of supply rails and the instaneous demand determines which set of output transistors are engaged. The original Carver M-400 cube amp worked this way. It had a +/- 30 volt supply, a +/- 50 volt supply and a +/- 80 volt supply with a complementary set of transistors across each supply. The efficiency is the lowest of these choices and switching issues and power supply problems lead many of these amps to early failure. I got one of the first ones as did many others in the audio club at work. Most blew up within a year or two but mine was still alive when I recently gave it away despite me using it in bridged mono mode (about 700 watts) as a guitar amp.
You don't need a DSP for the power supply control, just use a conventional SS amp connected in series with the output of a tube amp.....as to produce overall tube sound using only a few tube Watts. It is effectively a class G or H amplifier then.
I tried the circuit in your top schematic when you first posted it. I could never get it to work. The SS amp (I used a LM3886 chip) overpowered the output impedance of the tube amp. I never tried to really work on it though.
I now believe that it is possible to build a simple agile SMPS without a DSP, but the whole purpose of the design contest that provoked the amp in the first place was to find new and unique applications for Microchip's new dsPIC chips that were optimized for SMPS power supply use.
Aside from power output, how was the sound compared to a conventional power supply?
The output stage in most SS amplifier designs is based on a pair of complementary emitter followers. By design an emitter follower has good PSRR (power supply rejection ratio). This means that noise, crud, and other imperfections on the power supply won't pe passed on to the speaker as long as the headroom demands on the output stage are met. If we are going to be messing with the power supply knob in real time while the amp is playing, we need lots of PSRR. The typical common cathode tube stage won't cut it. The only useful choice is a cathode follower. So I designed and built a few tube amps with cathode follower output stages. My experiments were all SE but P-P can be done too. Details here:
20W cathode follower amplifier
The cathode follower amp designed above has a different sound than a typical SE tube amp. The sound is more dynamic, and the bass is solid. Like many SE tube amps, this amp can be pushed into clipping without the obvious harshness found in a solid state amp. Also the distortion characteristics are typical. The more power it makes, the higher the distortion. I still have it and now that I have a big power supply I must hook it back up.
The cathode follower amp with the DSP modulated power supply sounds similar up to a point. The measured distortion characteristics are atypical. The distortion settles at about 0.5% once the output power is high enough to overcome the noise, about 200 mW. The distortion stays nearly constant rising to 0.9% at 10 watts. The output stage sees a constant voltage across it, so it delivers a constant distortion....until the power supply can't go any higher, then things get ugly fast. It sounds like a solid state amp hitting clipping.
What are the chances you would rebuild the minitron using an Arduino for DSP?
For this application.....zero. The Microchip dsPIC chosen for the Minitron (and the Microtron and Megatron that only existed in the simulator) had some specialized hardware inside it that was designed for SMPS use. The agile buck converter that ran the power supply could run on its own with software needed only for initialization and setup. The rest of the chips processing power could be used for other tasks. There is no other microprocessor with this capability.
The original project submission (not the abstract) outlined a feature set that included auto bias, auto tweaking, several distortion profiles, and more. I never finished the code for all of that stuff, but some amp company in England had the balls to patent some of those concepts AFTER I published the article. They even used some of my verbage. That is what drew the emails from Peavey.
I have been working on refining those concepts on and off in the 5 years since I wrote those articles. I will eventually post some designs using those concepts. My current design is a guitar amp controlled by a microprocessor. It does not use power supply modulation, but there are some new tricks that I have not divulged yet. I did not choose an Arduino for this project, BUT I did use one of these:
Digilent Inc. - Digital Design Engineer's Source
Think of it as an Arduino on roids. It has the same form factor as an Arduino Mega, and can be programmed with Arduino sketches.
If you were to do that, I think you would grab the interest of a large number Arduino users.
I don't know how many Arduino users would also want to build a bad azz tube guitar amp, but.......
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 2nd May 2012, 06:32 PM   #15
SY's Avatar
Look at any of the schematics at Tube amplifiers for high-end audio by The David Berning Company for totally nontraditional approaches. David did solid state followers driving sweep tubes long before any of us ever even thought to use these parts. Look at the EA2-150- sweep tubes, screen drive, digital autobias, switching supplies... and in 1977!
If there's a sucker born every minute, where do the rest of them come from?
Old 2nd May 2012, 08:50 PM   #16
I knew that Berning did screen drive amps. I didn't realize WHEN he did them. In 1977 I was making audio amps, and big ones at that......they just didn't glow. All were sand based life forms back then.
I kind of drifted away from tubes in the early 1970's and didn't find my way back until I traded a car for a Scott 272 integrated amp in the 80's. I still have the amp. The car has been crushed and melted. I may be selling the amp soon though. It hasn't been plugged in in about 15 years.
In 1977 I had discovered the microprocessor and was attempting to make music with them. Of course working for the company that designed the 6800 and 6809 chips helped too.
Old 2nd May 2012, 08:52 PM   #17
SY's Avatar
In 1977, I was building very conventional tube amps. My first exposure to David's work rocked my world.
Old 3rd May 2012, 05:42 AM   #18
smoking-amp's Avatar
"I tried the circuit in your top schematic when you first posted it. I could never get it to work. The SS amp (I used a LM3886 chip) overpowered the output impedance of the tube amp. I never tried to really work on it though."
If the tube amp is lower power than the SS amp you have to use an OT with a lower output Z than the usual 8 Ohms. Basically the tube amp only contributes a fraction of the total output voltage at the same current when connected in series, so you can figure the secondary impedance (versus 8 Ohm) from the Watts ratio required. Typically the secondary will be under an Ohm, so the effective OT primary/secondary ratio is higher than normal, which then makes it a lot easier for the tubes to drive.
Ohms Law V = I R
Old 5th May 2012, 04:00 AM   #19
DJNUBZ is offline DJNUBZ  United States
If you build it, they will jam!
Old 5th May 2012, 04:16 AM   #20
Those are some of the coolest amps I have seen in a very long time. I would love to hear how they perform in person. It looks like he also designed the Milbert BAM car amplifier, an amp I have wanted to own for a very long time. It's a shame it's so expensive.
What I got for breaking my own rule.... JoeDJ Everything Else 4 19th July 2011 10:25 PM
Breaking in your tubes? Lingwendil Tubes / Valves 3 6th June 2009 04:48 AM
Breaking in speakers trai1824 Multi-Way 4 25th February 2008 05:32 AM
Breaking-in a subwoofer BAM Subwoofers 5 21st November 2001 12:59 AM
Copyright ©1999-2013 diyAudio
