ul - triode coupled screen grid resistor - diyAudio
Old 1st May 2012, 03:47 AM   #1
Default ul - triode coupled screen grid resistor
Hi all,
it just maybe newbie question.
May gurus here explain what did r62 or r63 in this schematic
did both on triode or ul mode?
Thanks for your help.
Old 1st May 2012, 10:00 AM   #2
DF96 is offline DF96  England
Possibly damping a high Q HF resonance in the transformer? Normally a snubber network would be used for this, as a plain resistor will absorb power throughout the audio spectrum.
Old 1st May 2012, 10:12 AM   #3
hidnplayr's Avatar
Possible the author used a break-before-make type op switch, and added the resistors so he can safely switch while the amp is powered on
Real tubes have top-caps
Old 1st May 2012, 01:49 PM   #4
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Since the screen switching is controlled by a relay it is unlikely that it is expected for one to turn off power to switch modes, else it won't work.
Therefore I concur with hidnplayr. The resistors insure a bias to the screens during the time the contact is switching.
Old 1st May 2012, 01:56 PM   #5
Yes, I agree. I hadn't spotted the switching. It would never occur to me to design an amp like that so I suppose I don't notice such things.
Old 2nd May 2012, 12:12 PM   #6
Hi ,
thanks all for your opinion
btw is there a way we can determine the correct values for this
resistor?
Old 2nd May 2012, 04:20 PM   #7
It needs to be low enough to provide some screen current and add some load to prevent switching spikes from getting too big, and high enough not to consume too much audio power under normal conditions. In a sense there is no correct value because this is not really the way to do it. Changing from triode-UL-pentode really needs a change to feedback etc. too otherwise for at least one of the modes you are running with the wrong setup.
Triode Operation Using The Screen Grids As The Control Grid - This Work? aldovan Tubes / Valves 9 20th May 2010 08:23 PM
Pentodes, triode mode and grid screen dissipation 101 duderduderini Tubes / Valves 3 22nd September 2008 01:48 AM
KT88 pp triode control grid resistor???? sbcellis Tubes / Valves 3 24th February 2007 03:00 PM
0v grid bias with UL connection? AudioGeek Tubes / Valves 0 8th July 2006 06:57 PM
screen-plate resistor and grid leak resistor metebalci Tubes / Valves 4 26th February 2004 03:18 AM
Copyright 1999-2017 diyAudio
