Opt laminations isolation
Old 29th April 2012, 11:40 AM   #1
RuiR is offline RuiR  Portugal
Default Opt laminations isolation
Hi.
Sorry if its a dumb question but i'm a newbie with a problem... accidentally when removing paint from a OPT to earth it accidentally i removed/grinded the paint in the laminations... do i have a problem?
Thanks in advance for any answer.
Rui
Old 29th April 2012, 12:43 PM   #2
pieter t is offline pieter t  Netherlands
Actually it is not paint but an oxyde layer (mat gray).
It must have been quite a job to remove that completely; when so the quality of the OPT will be pretty much impaired (eddy currents).
When you just removed the (usually black) paint from the sides of the complete built up transformer I would not bother too much.
Old 29th April 2012, 12:56 PM   #3
M Gregg is offline M Gregg  England
I think,
It depends on where and how much can you post a picture?
Then it will be possible to give a better answer.
As above the oxide coating insulates the laminations from each other so its depends on where you have damaged the Tx..
M. Gregg
Old 29th April 2012, 01:08 PM   #4
Thanks Pieter and Gregg
I have a picture but i cant upload it from the phone, as soon i arrive home i will upload from the desktop.
Again, thank you
Old 29th April 2012, 02:03 PM   #5
Again, thank you
Here it is...
What do you think about it?
Rui
Old 29th April 2012, 02:42 PM   #6
Rundmaus is offline Rundmaus  Germany
Rundmaus's Avatar
This shouldn't be a problem, as you shorted out only a few laminations on the outer edge of the core. No high magnetic flux there, and no large area damaged.
Greetings,
Andreas
EDIT: Remember that some lower quality transformer manufacturers weld the laminations together in two straight lines to save the money for screws and nuts. This shorts all laminations at these two places. Still work ok, though this is not recommended practice if you're building state-of-the-art output transformers.
Old 29th April 2012, 02:57 PM   #7
Good news
Next time i won't multitasking when building an amp. It cost more time and almost money.
Thank you Andreas
A great sunday to you all.
Old 29th April 2012, 03:33 PM   #8
nazaroo is offline nazaroo  Canada
Banned
Actually, the welding on transformers such as microwaves is designed to create small eddy currents for safety reasons and RF issues, not to save money on screws.
This practice would be disastrous for audio transformers.
I would strongly suggest you carefully take a knife along the cracks where you have ground them together and shorted them,
and scrap out those cracks just about an 1/8" or less,
and while you are doing this, work in some High Voltage (10,000 volt) insulating lacquer to correct your mistake.
Also, instead of grinding with such a coarse grit, switch to something a hell of a lot finer, like emery paper for finishing jewelry, and wipe down all dust with a damp (but almost dry) cloth.
Somebody warned that some rust-paints may contain iron oxide and be conductive, so I would look for a latex or acrylic primer meant for metal (to seal and prevent rust).
Make sure your primer/paint is non-conductive,
and use it sparingly.
Rather let the High Voltage lacquer get in the cracks between the laminations.
If you can't get lacquer, you might substitute a real mineral oil, which is what some laminations are baked in.
Old 29th April 2012, 03:36 PM   #9
As above,
Its not a major concern...However Is this the only damage IE you haven't done the same on the other side?
Believe it or not when it corrodes it will probably be better, LOL
M. Gregg
Old 29th April 2012, 04:07 PM   #10
Thank you nazaroo.
I don't think i will find 10.000 volt lacquer, the mineral oil approach seems to be the only alternative.
M. Gregg.... Yes it have, much smaller though, between two laminations.
When i think in all the care i had with this project wasted in one minute of pure distraction
Thank you all.
Opt laminations isolationHide this!Advertise here!
How to clean transformer laminations? rcbuck Power Supplies 15 22nd April 2012 06:46 AM
EI laminations in Europe overdrajv Parts 2 27th February 2009 08:09 PM
I Need Nickel Iron Laminations and Bobbins ! Nikolas Ojala Swap Meet 3 7th April 2008 03:57 PM
E/I transformer laminations; why? carpenter Pass Labs 41 19th September 2005 10:05 PM
MEZZO! Transverse laminations from TAD. kidder Multi-Way 2 24th April 2003 03:03 PM
