Old 4th January 2013, 05:09 PM   #71
Originally Posted by DF96 View Post
Could be a sign of spurious RF oscillation getting propagated along the heater wiring, rather than normal hum.
Not RF, looked at it on a scope. I first tried a 100 ohm balance pot and it worked but still had a little residual hum, using the caps no hum. I also tried connecting the caps with clip leads across different tubes and the result was the same. If it was some spurious pickup the results would have varied moving the clip leads around. Perhaps someone else can try it and see if they get the same results. I first used Illinois Capacitor coupling capacitors and the results were the same, I only went to ceramic caps because they are physically smaller.
Old 5th January 2013, 09:35 PM   #72
Originally Posted by wiredwithtubes View Post
I've found that on filament windings with no center tap bypassing both sides of the filament line with caps works better to eliminate hum than a balance pot. I used .47uf @ 100V ceramic caps.
Hello
Thank you very much.
Great idea, I hope these work for the higher power GU50 to.. That is 12.6V but I must have to check the tube data.
I have 12.5V DC also. Is not better if I use DC for the GU50.
Again I have to take a look at the tube data what is the recommendation. Great help, thanks one more time.
Greetings Gabor
Old 6th February 2013, 07:45 AM   #73
Looking for somebody who have AC heater with 300B and NO noise.
It could be possible as WE91 is ac ?
Thanks for your help.
Gilles.
Old 10th February 2013, 02:28 PM   #74
Default No noise??
Hi Gilles.
I'm getting 3.9mv and 2.9mv 100hz respectively at the terminals of my AC supplied JELabs 300B monoblocks. Nothing fancy here, just AC straight to a wirewound dropping resistor, routed around the outside and with a hum pot. I haven't tweaked it for optimum performance, just made sure the wires were twisted and placed to the outer edge of the chassis. Would be interesting to see what other folks are achieving and what measurement would be considered "No noise". (Now I've measured it I'm going to have to find out why I've got 1 mv difference. Damn!!)
Old 10th February 2013, 02:44 PM   #75
rongon is offline rongon  United States
rongon's Avatar
To echo valve5425's question, and out of my own curiosity, would 4mV of AC hum on the filaments of a 2A3 or 300B be considered objectionable?
Old 10th February 2013, 02:46 PM   #76
rongon's Avatar
If you wanted to use cathode bias on a DHT, but still use those .47uF bypassing caps for the filaments, where would you put the cathode bias resistor?
Old 21st February 2013, 04:06 AM   #77
Default How's this one look lads just finished the heater and power wiring
Any thoughts
Old 20th April 2013, 11:13 PM   #78
roline is offline roline  United States
roline's Avatar
Elevated twisted pair...
SO many tubes, SO little time!!!
Old 21st April 2013, 07:12 PM   #79
I should think you would just connect the resistor from filament to ground. But then the .47 caps would act like a bypass and boost at very high frequencies. I'm only familiar with DHT power output tubes and on a power tube you would want a decent value bypass cap. Might be best to use a separate filament transformer in such a case.
Politicians and diapers have one thing in common. They should both be changed regularly, and for the same reason.
The Good. The Bad and the Ugly Car Amps boxcustom Car Audio 115 17th August 2011 01:34 AM
OPT -the good, the bad or the ugly ?? AuroraB Tubes / Valves 1 9th February 2007 11:07 PM
The good, the bad, and the ugly OTL amplifiers Original Burnedfingers Tubes / Valves 46 9th November 2006 06:27 AM
Preamp Numbers; good, bad, ugly? chris ma Solid State 4 3rd September 2002 04:49 PM
Copyright ©1999-2013 diyAudio
