Heater Wiring - the Good the Bad and the Ugly - Page 13 - diyAudio
Old 24th October 2016, 04:23 PM   #121
DF96 is offline DF96  England
I would expect that the heater of a 12AX7 is one of the least likely ways for RF to sneak into an audio circuit, so I can't see the need for an RF choke. The pro is that it will do little harm. The con is that it is unnecessary.
Old 25th October 2016, 04:33 PM   #122
drlowmu is offline drlowmu  United States
Banned
Appreciated your input. I was not thinking about RF getting into the Driver tube, but I was thinking about snubbing all those nasty fields, inherent in the power transformer, and radiated from the power transformer itself, into the filament winding.
I am not sure what the fields from the two 500 uHY chokes will do, when in proximity to the tube socket, and all that low level signals present on the grid of the input tube, etc etc.
Granted, what I propose is NOT the normal way of executing the filaments. Its new. If ANYONE has any ideas on this, I would welcome input, and their thoughts. Don't hold back !!
Thanks so much !!
Jeff
Old 25th October 2016, 08:29 PM   #123
An RF choke is as likely to pick up a magnetic field as it is to stop a current from flowing. It will, of course, increase magnetic coupling (in both directions) between the heater wiring and other circuit loops.
"Snubbing" is not a word I would use for a low pass filter. The power transformer does not "radiate" any fields, as it is far too small for radiation to take place.
I fear you are proposing an inappropriate 'solution' to a non-problem. That may be why it appears to be "new". Good AC heater wiring practice is the thing to go for; very old, but it works.
Old 25th October 2016, 11:27 PM   #124
12E1 is offline 12E1  United Kingdom
12E1's Avatar
A choke of the type that you refer to will not help reduce common mode noise (data here). If there is any common mode noise from the supply (perhaps from some HF coupling from primary to secondary windings rather than through the magnetics) then a bifilar wound choke would be more suitable. Differential noise across the filament will be pretty unlikely in most cases and at the frequencies that this choke would block the noise would not be coming from the transformer in any case.
If hash getting on to the filament wiring is really a concern, then perhaps some simple decoupling either across the filament supply and from the filament supply to the chassis would be rather more effective (and a lot cheaper).
Also, are you looking at this in relation to directly heated or indirectly heated cathodes? In indirectly heated tubes the layout of the filament helps to prevent differential noise coupling to the cathode. With directly heated cathodes the problems are more to do with either hum cancellation if AC driven, or suitable voltage or current regulation if DC driven.
However, I am with DF96 on this. This really shouldn't be a problem if care is taken over the wiring layout as described previously in this thread.
Old 26th October 2016, 07:31 PM   #125
Banned
Thank you so much for commenting !! Appreciated. I am talking about a Driver tube, indirectly heated, high mu ( 1/2 12AX7, 6SL7, 12BZ7, etc. ), directly coupled to and driving a DHT 2A3, etc etc.
If anyone else cares to comment, feel free !! Thanks.
Jeff
Old 20th November 2016, 06:13 PM   #126
I do like inductors on DHT cathode circuits. for some reason I like its character it imparts.
I treat indirect heated tubes different depending on the situation.
as far as DrLowmu's issue, I would have to see an o-scope picture to determine the origin and determine the correct methodology to apply to the circuit.
Old 26th November 2016, 09:59 PM   #127
AllenB is offline AllenB  Australia
How about using a RF Hash Choke right at the filament pins on the tube socket ?
Morgan Jones talks of using an RF common mode choke in the feed to heaters, followed by balanced capacitors to chassis to, I presume reduce electrostatically coupled noise via the cathode.
Small chokes are often used as a series addition to larger inductors to improve their parasitic characteristics, extending bandwith, and inductors have been successfully used with filaments to separate signal from supply albeit a less practical way to do things.
Old 28th November 2016, 03:27 PM   #128
Hi gang!
I'm working on laying out my 1st amp and I'm in the process of bathing parts and laying things out with Adobe Illustrator. I'm building a Chubby Clementine amp with point to point construction KT88 power tubes and 6SN7 pre tube. See below for the heater circuit off the 6.3V secondaries.
Here are a few questions for the heater wires:
1) what brand / type / gauge of solid wire?
2) what order should I run the wires to the tubes? Should I tie into the 2 power tubes first, or start at the pre tube?
3) what would be your preference for the two colors I should use?
Thanks! This thread has been very informative!
File Type: png Screen Shot 2016-11-28 at 11.12.07 AM.png (14.4 KB, 313 views)
Old 28th November 2016, 11:27 PM   #129
TonyTecson's Avatar
some reference....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 29th November 2016, 09:52 AM   #130
Solid insulated copper wire of the right thickness to carry the current while under a hot chassis is what you need. For 3A of heater current I used cores from 20A mains cable. Ignore brand. Twist the wire tightly - there is lots of information online about how to do AC heater wiring. Do power valves first, so there is not too much AC current near the small signal section. You can use thinner wire for the smaller valves.
My cables happened to be red and black, but colour does not matter. It should be obvious which is the heater wiring, and AC does not need to show polarity.
The Good. The Bad and the Ugly Car Amps boxcustom Car Audio 115 17th August 2011 01:34 AM
OPT -the good, the bad or the ugly ?? AuroraB Tubes / Valves 1 9th February 2007 11:07 PM
The good, the bad, and the ugly OTL amplifiers Burnedfingers Tubes / Valves 46 9th November 2006 06:27 AM
Preamp Numbers; good, bad, ugly? chris ma Solid State 4 3rd September 2002 04:49 PM
Copyright 1999-2017 diyAudio
