Heater Wiring - the Good the Bad and the Ugly
Old 11th December 2012, 01:13 PM   #61
DF96 is offline DF96  England
Solid cores are better for heaters as the wires stay where you put them. Screened twisted pair cables almost certainly don't have a tight enough twist to deal with the magnetic field. Stick to the tried and tested method: solid core, tightly twisted, no need for a screen if done properly.
Old 12th December 2012, 04:25 AM   #62
Goodlagger is offline Goodlagger  Australia
Default Shielded cable
Thanks DF I thought the shield would suppress the field almost to zero if grounded but if that's how it's always been done who am I to break tradition
Old 12th December 2012, 11:25 AM   #63
The shield will suppress the electric field but not stop the magnetic field. A heater winding CT or humdinger pot will also deal with the electric field. Tight twisting reduces both fields for anything which is further away than the twist length, hence a tight twist is needed.
Old 13th December 2012, 03:02 PM   #64
Miswiring heaters is unlikely to blow 450V caps.
12AX7 and some other twin triodes (but not all) have heaters which involve pins 4, 5 and 9.
Old 16th December 2012, 07:55 PM   #65
Sheldon is offline Sheldon  United States
They might have been connected to AC?
Old 16th December 2012, 08:47 PM   #66
I suppose anything is possible! Would 6.3V AC blow a 450V electrolytic?
Remote debugging when we don't know what he did, and probably he doesn't know what he did, is not easy.
Old 17th December 2012, 01:52 AM   #67
12E1 is offline 12E1  United Kingdom
12E1's Avatar
I don't know the specifics of the amp in question, but if mis-wiring the 6.3V AC also took out the rectifier for the HT, either by a direct short or through some other component breakdown, then the caps might see high voltage AC... for a short while...
Low voltage AC could do the damage but I'd expect it to take longer.
Old 17th December 2012, 11:09 AM   #68
Originally Posted by gkenne
connecting pins 4 & 5 of the EL84 to pins 4 & 5 of the 12AX7s,
That won't work. Most B9A valves have the heater on pins 4 and 5, but some double triodes have a different arrangement involving pin 9 too. For these, such as 12AX7, you connect 4 and 5 together, then wire the heater supply to 4/5 and 9. Or you can use 12.6V on 4 and 5, ignoring pin 9.
Old 4th January 2013, 03:49 AM   #69
wiredwithtubes is offline wiredwithtubes  United States
I've found that on filament windings with no center tap bypassing both sides of the filament line with caps works better to eliminate hum than a balance pot. I used .47uf @ 100V ceramic caps.
Old 4th January 2013, 10:30 AM   #70
Could be a sign of spurious RF oscillation getting propagated along the heater wiring, rather than normal hum.
Heater Wiring - the Good the Bad and the UglyHide this!Advertise here!
The Good. The Bad and the Ugly Car Amps boxcustom Car Audio 115 17th August 2011 02:34 AM
OPT -the good, the bad or the ugly ?? AuroraB Tubes / Valves 1 10th February 2007 12:07 AM
The good, the bad, and the ugly OTL amplifiers Burnedfingers Tubes / Valves 46 9th November 2006 07:27 AM
Preamp Numbers; good, bad, ugly? chris ma Solid State 4 3rd September 2002 05:49 PM
Copyright ©1999-2017 diyAudio
