Heater Wiring - the Good the Bad and the Ugly
Old 11th January 2017, 10:12 PM   #131
finom1 is offline finom1  United States
Two Types of Tube Amplifier Hum and How to Determine the Source
YouTube
Old 10th April 2017, 06:20 PM   #132
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
The best way is to put their respective magnetic axis at 90 between them. This is true if no more than 3 cores are in the set, if 4 or more, then you will need careful cut and try, and shielding.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 11th April 2017, 05:25 PM   #133
OK, good luck‼
Heater Wiring - the Good the Bad and the UglyHide this!Advertise here!
The Good. The Bad and the Ugly Car Amps boxcustom Car Audio 115 17th August 2011 02:34 AM
OPT -the good, the bad or the ugly ?? AuroraB Tubes / Valves 1 10th February 2007 12:07 AM
The good, the bad, and the ugly OTL amplifiers Burnedfingers Tubes / Valves 46 9th November 2006 07:27 AM
Preamp Numbers; good, bad, ugly? chris ma Solid State 4 3rd September 2002 05:49 PM
