Old 28th April 2012, 08:43 AM   #1
M Gregg is offline M Gregg  United Kingdom
M Gregg's Avatar
Default Pot mechanical resistance "Feel" and restoration..
OK,
I asked this question in another thread, however I think it is quite important for restoration purposes in particular old tube equipment.
Pots have a mechanical resistance to the motion that gives a luxury "Feel"..
If you clean a pot with something like servisol 10 and the grease or whatever gets disolved...I guess I should add that Servisol 10 works very well and contains a track lubricant (Make sure the plastic in the pot is OK before using it, But I have had very good results) Its just that there is some "Mystic" compound that is put on the shaft that gives this luxury feel...and no one seems to know on the WEB what is used in the factorys to get this feel..
Does anyone know what to put back on the shaft of a pot to get the mechanical resistive feel back after a clean..I guess you could put it on the shaft on the outside of the pot and let it creep in.(capillary effect) It can only be some Kind of grease..it feels a bit like tar to the touch but dosen't set...
BTW WD40 makes pots worse...
M. Gregg
What is the sound of one hand clapping?
Old 28th April 2012, 08:48 AM   #2
Try that copper coloured anti-seize compound.
Old 28th April 2012, 08:51 AM   #3
M Gregg's Avatar
I guess you have tried this then?
It would be interesting to know what they actually use..
Thinking about it the top is resistive when it comes of the tube..only concern might be if the compound is conductive?
Even the small cheap as chips types sometimes have it..
M. Gregg
Old 28th April 2012, 11:17 AM   #4
I use highpressure aerosol grease from Berner.
Liquide and flows easily when sprayed and then sets to sticky HD bearing grease.
Perhaps sticky chainoil or some other gluetype spayon grease does the same trick.
Old 28th April 2012, 11:24 AM   #5
Flatheadmurre beat me to it.
Spray grease or chain lube works really well.I just fixed up a guitar amp and cleaned the pots, they lost the nice sort of feel but a little squirt of chain lube and leave it for a bit and it was l back to normal.
Cheers Matt.
Old 28th April 2012, 12:09 PM   #6
This - Kilopoise Range | ROCOL - Industrial Lubricants, Metalworking Fluids & Traffic Management was probably the type of thing used originally.
Old 28th April 2012, 12:12 PM   #7
Caig Labs offers DeoxIT Fader L series, for this very purpose.
Eli D.
How to calculate mechanical resistance added by enclosure. SoulMagnet Subwoofers 0 10th January 2012 06:25 AM
Quad 34 preamp tilt pot resistance ? Zigis Analog Line Level 4 8th September 2010 02:13 AM
Digital pot resistance measurement rtarbell Parts 1 8th February 2008 06:10 PM
ALPS 27 Pot, what resistance? timothygurney Parts 3 31st January 2008 12:45 AM
Volume control : - pot' or pot' variable feedback resistor (gain) ? ash_dac Solid State 5 1st August 2006 05:07 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
