Line stage with u-follower and nfb - diyAudio
Old 24th April 2012, 05:12 PM   #1
Default Line stage with u-follower and nfb
I'm planning to build a u-follower line stage with a gain of about 4-5 and a reasonably low output impedance. My tube of choice would be 6FQ7 / 6CG7.
Without any nfb, the gain would be too high for my purposes so I'm thinking of applying nfb as in the schematic below (R5 and R4).
Any opinions/experiences on this topology? I'm a bit worried that the nfb could mess with the nice sound of the 6CG7.
Edit: R6 and C2 represent the input impedance of the power amp + cable.
Old 25th April 2012, 04:37 AM   #2
I built mine a 12AU7 based closed loop (with nfb) mu follower in mid 90s. It sounds very good. Just a few dB of NFB not a problem.
C4 is way too big use .01uf. You also need to add :
1. a resistor from the junction of R3,R4 to ground .
2. a dc drain resistor (1M) in shunt with R6.
3. Bypass cap across lower cathode resistor R2.
Remember that you need to power up the mu follower first, wait for a minute b4 powering up your power amp if you decide not use an output muting relay.
Art
Old 25th April 2012, 11:56 AM   #3
Thanks for your comments. The schematic was just to illustrate the topology. The final version will have grid stoppers, bleeder resistors at the output, etc.
Old 25th April 2012, 01:58 PM   #4
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
A suggestion: you can put a small Cap in parallel with R4 to adjust the HF gain, and then, to compensate the large capacitive load.
Regards.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 26th April 2012, 09:13 PM   #5
ruffrecords's Avatar
Mu followers based on the 6CG7 are capable of very low distortion and excellent noise performance. With NFB the distortion will be even lower.
I would make the following recommendations:
1. Decouple the lower cathode bias resistor. The low distortion of the mu follower is due to the plate load seen by the lower tube being many times its ra. By not decoupling the cathode resistor of the lower triode you unnecessarily increase its ra and hence increase distortion. 220uF should do it.
2. R1 gets multiplied by the top tube mu to form the plate load for the bottom tube. For minimum distortion I would recommend increasing R1 to 10K.
3. The 6CG7 seems to produce the least distortion around 5mA idle current. To achieve this , R2 and R3 should be increased to 1K.
4. C4 can be reduced to 100nF. The 470K (R7) is bootstrapped by the top tube acting as a cathode follower.
5. You should elevate the heaters to around 75V or so to avoid exceeding Vhk of the top tube.
Cheers
Ian
Old 26th April 2012, 10:41 PM   #6
stokessd's Avatar
I did something similar years ago and the NFB improves the linestage in every way. Better frequency response, lower distortion, lower gain, it's all so much better with NFB.
http://www.quadesl.com/pdf/lineamp.pdf
Sheldon
Old 26th April 2012, 11:00 PM   #7
Sheldon
I am not surprised you needed NFB. The schematic you posted is an SRPP topology which is well known for its excellent drive capability and high distortion. Definitely needs NFB. A mu follower without NFB will beat an SRPP any day.
Cheers
Ian
3 stage LIN topology - NFB tappings? AndrewT Solid State 66 3rd January 2013 10:49 AM
Integrated No NFB Son of Follower VladimirK Solid State 42 23rd September 2011 05:59 PM
Voltage gain stage for Non-NFB MOSFET current amp gripracer Solid State 50 23rd October 2009 03:37 AM
Aikido line stage - plus phono line stage cjkpkg Tubes / Valves 1 22nd November 2008 10:50 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 05:07 AM
Copyright 1999-2017 diyAudio
