does the 3A5 have the stones to drive a 2A3?
Old 23rd April 2012, 02:20 AM   #1
Bigun is offline Bigun  Canada
Bigun's Avatar
Default does the 3A5 have the stones to drive a 2A3?
Thinking of DHT driving DHT, two stage only which means I need some gain from the driver. The 3A5 has a mu of 15 (data sheet attached), not exactly high. Is there a DHT with more mu than this one ?
I know the Fi 2A3 has a 'weak' driver (< 1mA plate current supposedly) but I wonder - does the 3A5 have what it takes to drive a 2A3 and
after all is said and done, is the 3A5 very linear ?
I found only one set of curves of any use... and they are attributed to a website that no longer exists. Where I found them is here: Phono Preamplifier with 3a5 Directly Heated Triode
edit: here's how I figure out the gain of the amp. mu of 3A5 x mu of 2A3 = 15 x 4 = 60
with 5k OPT into 8R the voltage ratio is 25, so the gain of the amp is 60/25 = 2.4
that's not really going to do me much use is it....
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 23rd April 2012, 06:22 AM   #2
dsavitsk is offline dsavitsk  United States
dsavitsk's Avatar
Maybe not, but maybe. Leaving aside the fact that you have likely overestimated the gain you will realize, if you feed your amp with a 2Vrms signal and have a gain of 2.4, you end up with 4.8Vrms on the output. W = V^2/R = (4.8)(4.8)/8 = ~2.8W. So, you are not quite pushing the 2A3 all the way, but you are actually pretty close. If you have a preamp, or a source with a hot signal, then you are OK.
Old 23rd April 2012, 07:49 AM   #3
revintage is offline revintage
The loadline you have drawn is pretty useless as it doesn´t allow a descent swing and also is in a very unlinear area. With a correct working point the tube is very linear. If you use http://www.revintage.se/triodecalc.xls you can check both max outputvoltage and 2nd order distortion.
If you parallell the two halves(guess you planned that already) and go for something like 4mA/110V, using CCS load you could maybe make it work. Then do a loadline with 2A3s gridleak resistor as load, with parallelled halves you off course double the the load(ie if grid leak is 100k you use 200k).
Old 23rd April 2012, 07:55 AM   #4
vinylkid58 is online now vinylkid58  Canada
vinylkid58's Avatar
Why not pick another tube that will easily drive a 2A3? There are a lot of choices.
jeff
Old 23rd April 2012, 08:19 AM   #5
Hey Jeff,
I fully understand Biguns interest in this concept.
Would be glad for advice of other DHT drivers with the same or higher mu, also with good linearity.
There might be some lesser known pentode to triode-strap.
Old 23rd April 2012, 08:20 AM   #6
andyjevans is offline andyjevans  United Kingdom
I've been building with 300b SET and with 2a3 PP. Need the watts for my Alpair 10s. With the 300b SET I use a 46 as a driver into the Hammond 126C interstage. I could also use a 4P1L or a 31 or a 71A or a 2a3 into that interstage. I don't use a cathode bypass (they suck) and the 46 into the 126C works nicely without one. I thought it was the best of the bunch, but haven't really tried the 4P1L enough.
With DHTs you're pretty much looking at 3 stages - I use a 26 preamp with 5 ohm (40W) filament bias, starved filaments of 1.2v, 95v anode and two Hammond 156C anode chokes in series and with a FT-2 output cap. This is so good that three stages work fine for me.
The 3a5 is a fine tube - no question. I haven't used it with 2 halves joined but I've used it in PP in line stages and DAC output. A similar double triode is the 1J6 - take you pick. 3a5 is leaner, 1J6 more lush. I'd suggest using either with two Hammond 156c plate chokes in series - bottom to bottom and one phase reversed so they are hum bucking. They need to be kept away from magnetic fields since they can pick up hum, but they sound glorious with the higher Ra tubes like 3a5 or 1J6 or 26 - you have inductance of 300H so you'd probably not need a cathode bypass. Filament bias would be even better if the voltages stack up - it's really only convenient for low bias voltages hence running the 26 in my preamp at 4.6v bias on the cathode. I guess you could use the 26 like that as a driver. On the agenda is direct coupling the first two stages - maybe even 26 to 26.
There are no higher mu DHTs worth using. Ra goes through the roof with tubes like 40. With my 2a3 PP amps I've been using a differential 6SN7 driver with the 90K half of a Hammond 124b used as an anode choke. This works like a dream. I've also tried a pair of 4P1L here which works OK. If it has to be indirectly heated I'd look at a 2C22. Possibly a ECC40 which is as good as a E80CC. But I'd stick to DHT solutions and 3 stages
andy
Old 23rd April 2012, 09:44 AM   #7
A 2A3 is normally built like a 3A5, dual-plate with the elements parallelled. After having seen Andys recommendation of 3A5 we have used it in a 1545 DAC interface with parallelled halves. Sounds great. DHT-buffered NOS-dac
On paper tube data looks good with S=3,6 mA/V , Ri=4,2k and mu=15.
It will not work with resistive load as the loadline will be to steep. So why not go for two 156C in series(at below 8mA) as Andy suggests. With a CCS heater through the cathode resistor no bypass will be needed. Sensitivity will be something like 2,3Vrms.
Think I must sim this. Any figures on 156C capacitance?
Old 23rd April 2012, 10:13 AM   #8
Rod Coleman is offline Rod Coleman  United Kingdom
работник
Rod Coleman's Avatar
The 3A5 can easily answer the call!
With shunt cascode (the best sounding 300B driver I have made) you can drive 2A3 to full output with only 0,6V rms.
The 3A5 is very easy to use with filament bias, so I have drawn that, and drive it with my Filament Regulators (shameless, I know).
Shunt-cascode + Filament bias means NO capacitors in the signal path, except the output coupler.
Old 23rd April 2012, 10:54 AM   #9
Have not tried your shunt cascode IRL, Rod. Have simmed it with E88CC though and it works like a charm. But maybe the tube-talibans will puke when seeing the BJT.
Old 23rd April 2012, 11:01 AM   #10
работник
Yes, Lars they will hate it!
But they do not appreciate that the BJT is simply using its mighty gm to hold the anode voltage steady, while passing a variable current.
You can compare a BJT vs triode in this capacity, very easily. Just make a standard series-cascode stage with any triode on the bottom, any triode on the top. If you swap the UPSTAIRS triode around, it is quickly evident that high-gm triodes sound best. Last of all, compare the best triode with an NPN BJT - which easily surpasses all.
does the 3A5 have the stones to drive a 2A3?Hide this!Advertise here!
More magic stones and hockey pucks jackinnj The Lounge 285 22nd October 2012 01:35 AM
Anyone used C3G to drive a 2A3 before? d3aPentode Tubes / Valves 1 7th December 2009 07:24 AM
Can 3.5W 2A3 amp drive proAc 1SC? kokheng Tubes / Valves 4 22nd September 2008 01:16 PM
Some Girls might be one of my favourite 3 Rolling Stones albums bikehorn Music 0 30th November 2006 01:57 AM
Ability of a PP 2A3 amp to drive 90db speakers? G Tubes / Valves 32 27th June 2003 05:43 AM
Copyright ©1999-2017 diyAudio
