My amp is motorboating, improve it with b+ regulator ?
Old 24th May 2012, 08:19 PM   #91
LinuksGuru is offline LinuksGuru  Europe
I took a closer look to the schematic. IMHO there are some oddities, both on original from
Integrated5050
and the one modified and built by yurgs.
1) What is the reason of paralleling 2 triodes of the input pre-driver? I see none whatsoever. Additionally, in the original amp pre-driver have 2.5mA anode current, and yurgs' - 5mA (according to his schematic, 10mA / 2 = 5 mA).
2) Paralleling triodes in LTP - another unnecessary complexity.
3) CCS (constant current sink, MJE340) in LTP - really odd connection. Tail of the LTP doesn't seem to be connected to the ground anywhere. Emitter of MJE340 must be grounded, instead, it is connected to -87V BIAS supply. I think this is an error on the drawing (from Turneraudio).
Old 24th May 2012, 09:05 PM   #92
richwalters is offline richwalters
richwalters's Avatar
post 89 Yurg
Don't go spending into KT90's if the amp is not behaving properly; Currently your amp isn't stable. With these highish gm tubes, UL screen taps to anode R/C's is a must otherwise one can do damage.
Once stable, with KT90's fitted, expect around 20% more output power compared to KT88's. EH KT90's like more current on the UL screens and perform best with a lowish imped G1 drive. If one is after long life then OK; 475V is an easy voltage for these tubes.
richy
Old 24th May 2012, 10:16 PM   #93
12E1 is offline 12E1  United Kingdom
12E1's Avatar
The circuit seems perfectly OK to me. If the CCS was returned to ground then there would be very little voltage developed across it to ensure correct operation, and the other input (currently -24V) would of course need to be changed.
The current sink as drawn will work fine so long as the -87V and -24V rails are clean and the two rails are referenced to the signal ground (not to chassis). The current level is of course defined by the voltage developed across the 5.3K resistor (about 62 volts) which results in 11.7mA (hence nominally 6mA either side of the LTP).
Old 25th May 2012, 10:37 AM   #94
yurgs is offline yurgs
3) CCS (constant current sink, MJE340) in LTP - really odd connection. .
1.the main reason is to reduce noise, the original circuit runs 6cg7 and in my amp its 5814A, which have less gain. therefore are set at 5mA each.
3. Works fine, at least in regards to current.
@Richy, i never had anything else than KT90s and they were cheap when i bought them a while ago..
@Audio Asylum: your paralleled Bias resistors = 666.6r
is there some improvement in sonics when using satanic valued resistors?
Old 7th June 2012, 02:58 PM   #95
soulmerchant is offline soulmerchant  Switzerland
soulmerchant's Avatar
Once (a long time ago) I paralleled some valves and forgot to use grid stopper resistors. The amplifier was an instant motorboat... bububububububububub!
Addition of 300 to 1k Ohm grid stoppers on the paralleled sections fixed it immediately.
Look at V3 and V4 in the schematic posted just recently.
Ian
Old 7th June 2012, 03:09 PM   #96
Looking at the earliest schematic in this post, is a separate R10 resistor used for each grid or did you tie the grids together and use a single R10?
If not, please use a separate R10 resistor for each grid and tell me if this solves it.
Ian
Old 13th June 2012, 09:52 PM   #97
tomchr is offline tomchr  Canada
tomchr's Avatar
So... Yurgs. Did you get your motor boating (or whatever it was) issue solved?
~Tom
Modulus-86: 40W/8Ω @ 0.000061% THD. HP-1: 3W/20Ω, 450mW/300Ω @ 0.000032% THD. DG300B and Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 21st June 2012, 07:47 AM   #98
Hey there, sorry for the time it takes to get back to you guys.
I am away from home for work reasons, and that will unfortunately take until the end of July. so no amp work for me :-( i managed to get the parts for my blown sound card interface, at least i am able to measure again.
i will test with a 4ohm load first and then try the gridstoppers,
yurgs
Old 25th January 2013, 08:47 AM   #99
hey there.
sometimes life gets in the way of things....
I was not able to put much time towards the amp project, but i should be able to deal with things now.
1. i changed the load to 4r, with no change in the squeeging.
2. i took out the ccs on v1 and v2, and used resistive anode-loads and i replaced the 5814 with e12AU7,
so the circuit is basically as it was designed originally, the problems stayed the same though.
Old 25th January 2013, 09:22 AM   #100
3. i checked the source,
the cleanest source i have is a pc with a soundcard 192khz
pic 7496 shows two traces of 10kHz, top=source, bottom= ampoutput at 1W
pic 7497 shows the same @ Timebase 10uS
the spikes on the top trace must be the 192kHz, and the botom trace shows the "swinging" of the trace, i hope the photo shows it a bit.
4. i disconnected the driver at c26, and measured with the oscilloscope, and it looks like the trace doesn't change
pic 7499 shows two traces of 10kHz, top=source, bottom= V2 -output
pic 7500 is the same at a timebase of 2uS
there are still the lines "bluring" the trace on the output of v2. (the problem must be caused in V1/V2, the sound of the squeeging disapears though, it's made audible by the output tubes, )
My amp is motorboating, improve it with b+ regulator ?Hide this!Advertise here!
6L6 PP amp motorboating chrish Tubes / Valves 3 7th May 2011 10:30 AM
how can i improve this headphone amp bluegrass Solid State 3 29th March 2011 03:50 PM
Chip Amp - Motorboating putt putt noise? john65b Chip Amps 21 13th April 2007 08:46 AM
How to improve this amp thermonuclear Chip Amps 2 13th September 2005 07:38 AM
Please,can you improve this amp, let me know how destroyer X Solid State 17 25th April 2004 10:45 PM
Copyright ©1999-2017 diyAudio
