Old 28th May 2012, 11:12 PM   #41
tinitus is online now tinitus  Europe
Originally Posted by bigaudioscotto View Post
Here is a picture of the SE KT88.
looking very nice
whats inside the box
Old 29th May 2012, 12:10 AM   #42
Inside looks kind of like a rats nest but it sounds fantastic.
Old 29th May 2012, 03:41 AM   #43
alexg is offline alexg  Philippines
alexg's Avatar
Guys would there be an increase in bass
by changing the .22uf coupling cap to .68uf
with no ill effects.
I doubt that you will hear more bass.
There are coupling capacitor calculators and the resulting low frequency on the net.
Old 29th May 2012, 08:09 AM   #44
By using resistors in the place of the choke, you increased the outpout resistance of your power supply.
This causes problems in damping, especially in the bass. The power supply cannot keep up with the fluctuating demand if the output stage.
You need to install the choke to improve the bass.
I am running an EL34 SE here, my design. I have a 7H choke, I got it off ebay.
Old 29th May 2012, 10:41 AM   #45
That is great advice,had not even thought about the choke
but it makes more sense to start there.
thanks for the heads up.
Scott
Old 29th May 2012, 11:10 AM   #46
I was looking at the Hammond 155G 7H, 40ma, 340 ohms, 400VDC
is that voltage high enough.
it looks like they don't make one in 500volt for 300 ohms that
is what I am using now with the resistors.
any suggestions or will I be fine with that Hammond.
Old 29th May 2012, 11:18 AM   #47
well the "economy line" of Hammonds seems to be unsafe with 500Volts, you should look for their 193 Series, and find one that is rated for the current your amplifiers draws.
Old 29th May 2012, 11:59 AM   #48
Also, the less Ohms the better the performance.
Old 29th May 2012, 09:52 PM   #49
I will do the 193 series.
Old 7th July 2012, 11:44 AM   #50
Default Sub Out ?
How can I add a Sub output to this amp.
Scott
6CA7 Mikael Abdellah's KT88 SE amp? porkchop61 Tubes / Valves 24 20th February 2011 03:31 PM
Improvements for the Mikael Abdellah KT88??? 69CamaroSS396 Tubes / Valves 42 16th December 2009 01:58 AM
Mikale Abdellah SE KT88 B+ voltage? kacernator Tubes / Valves 7 27th February 2008 09:02 AM
Mikael Abdellah SE KT88 ideas and questions kacernator Tubes / Valves 6 14th January 2008 01:09 PM
Looking for KT88 Amplifier Schematic by Mikael Abdellah jduffy Tubes / Valves 6 5th April 2007 09:02 PM
Copyright ©1999-2013 diyAudio
