Those Magnificent Television Tubes - Page 84 - diyAudio
Old 8th April 2017, 01:44 AM   #831
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Originally Posted by mcl2k6 View Post
What I couldn't yet find out is how could the optimal value of the Schade be found out, or better, what tube parameter(s) does it depends on? Does the previous stage - basically the driver tube - has any effect on the amount of Schade to be applied?
With 6N1P driver I found that 100k seems to be the best for 6P36S, but this was determined experimentally by countless exchanging of the resistors, and running swept sine analysis, and checking the THD afterwards.
It is not about the value of the resistor per se; it is about feedback ratio that this resistor with anode load resistor provide. And it is about the driver that drives the thingy loaded on low parallel feedback resistance adding own Ri into the equation, so adding feedback to the output of a triode driver it is not unequivocally are you improving sound quality or harming it.
Everything has to be optimized as a whole. No rules of thumb here.
The Devil is not so terrible as his math model is!
Old 6th May 2017, 08:41 PM   #832
sser2 is offline sser2  United States
Default What happened to this thread?
There used to be over 100 pages, now only 86. My yesterday's post disappeared, among other things.
Old 6th May 2017, 08:55 PM   #833
vinylkid58's Avatar
Over here maybe?: More Ruminations on Screen Drive/Crazy Drive
jeff
Old 6th May 2017, 11:49 PM   #834
TonyTecson's Avatar
yes, the thread was split....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
MOAK: The Mother of All Karlsonators (aka The Magnificent Monster) DeonC Subwoofers 126 23rd January 2015 03:35 PM
Television question... toptip Everything Else 6 23rd October 2012 06:50 PM
Surround sound amp, Sub woofer and television warrennyc Subwoofers 4 3rd January 2005 10:33 AM
distance from television ALFIrE Multi-Way 2 30th March 2004 06:46 AM
Television broken Bull Everything Else 3 21st January 2003 12:08 AM
Copyright 1999-2017 diyAudio
