Those Magnificent Television Tubes
Old 22nd April 2012, 12:36 PM   #11
barretter is offline barretter  United Kingdom
I've had EC86s as the second stage in my phono preamp for years now without any precautions other than a grid-stopper to one of the grids and they've never given me any trouble unlike the triode-connected D3as I used to have as the front end. I use triode-connected E810Fs in that position now, with a similar lack of drama.
Old 22nd April 2012, 12:49 PM   #12
hidnplayr is offline hidnplayr  Belgium
hidnplayr's Avatar
Some more about the EL/PL36
CHAMP ELECTRONICS
Champ CBA-500 Bass Guitar Amp
Also, hupse claims: "The original mullard EL36 is an octal variant of the EL6"
Here is the EL6 datasheet wich might help get you started with the EL36 in audio.
http://www.mif.pg.gda.pl/homepages/f.../046/e/EL6.pdf
PS: talking about the in-box oscillators, ever tried to tame a PL802?
Real tubes have top-caps
Old 22nd April 2012, 01:13 PM   #13
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
Hidnplayer,
your original Mullard EL36's aren't the same as those dealt in the Champ and Australian articles!
Best regards!
Old 22nd April 2012, 02:39 PM   #14
Yvesm is offline Yvesm  France
Yvesm's Avatar
Yeap
A wonderfull driver !
Yves.
Old 22nd April 2012, 04:17 PM   #15
Fuling is offline Fuling  Sweden
I have used PC86 in several projects where Ive wanted a bit of gain and voltage swing. Never seen one oscillate and I only use one grid stopper in the kiloohm range.
Old 22nd April 2012, 05:19 PM   #16
hidnplayr's Avatar
And how can you be so sure that it not oscillates?
Old 22nd April 2012, 06:59 PM   #17
Koifarm is offline Koifarm  Netherlands
Koifarm's Avatar
Nice thread.
I have a couple of new telefunken PC86, will they sound as the ECC types?
Ronny
Old 22nd April 2012, 09:15 PM   #18
JohanB is offline JohanB  Sweden
Originally Posted by Koifarm View Post
Nice thread.
Ronny
A well built premium brand PC/EC86 or the special quality type E86C (with gold pins) has more gain, lower noise and is a more linear triode than E88CC types. Should then preferbly be run with over 5mA anode current and at least 100-120VDC to avoid grid current.
http://frank.pocnet.net/sheets/062/e/E86C.pdf
In order to run a PC86 (3,8V, 300mA) on a 6,3V heater voltage you just need a 8,2 Ohm, 1-2W resistor in series with the heater.
Johan
Old 22nd April 2012, 10:25 PM   #19
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
Most readers here know that I have been playing with TV tubes since the 60's when they were free for the taking at the local trash dump. I have been going through my tube collection sorting out the stuff to keep, and the stuff that must find a new home. In the process I have found a few oddities that even I didn't know existed.
Ever seen an EL84 with a plate cap????? Yeah I didn't think so until I had it in my hand. This one is made in the USA by Sylvania and has a 1980 date code. It is an EL804. The specs reveal that it is really a 6CW5/EL86 with a plate cap.
Most of us here know by now that the venerable 6L6GA was repurposed as a transmitting tube, the 807, and a sweep tube, the 6BG6GA. Do you know that it was also stuffed into a 6V6GT sized envelope and sold as a sweep tube for smaller TV sets? Would you want to find some NOS black plate RCA 6L6GA's in a tiny bottle with a different pinout for $3 each?
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 22nd April 2012, 11:25 PM   #20
Fenris is offline Fenris  United States
I just finished (powered up and tested today) an amp using a pair of 13DE7 TV tubes. I'll post the details in a new thread so this one doesn't get polluted.
Listen to the music through the stereo, not the stereo through the music.
Those Magnificent Television TubesHide this!Advertise here!
MOAK: The Mother of All Karlsonators (aka The Magnificent Monster) DeonC Subwoofers 126 23rd January 2015 03:35 PM
Television question... toptip Everything Else 6 23rd October 2012 06:50 PM
Surround sound amp, Sub woofer and television warrennyc Subwoofers 4 3rd January 2005 10:33 AM
distance from television ALFIrE Multi-Way 2 30th March 2004 06:46 AM
Television broken Bull Everything Else 3 21st January 2003 12:08 AM
