Those Magnificent Television Tubes
Old 18th January 2018, 09:21 PM   #1021
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
thanks Don....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 26th January 2018, 07:40 AM   #1022
Tyimo is offline Tyimo  Hungary
Hi!
Could anyone tell me the 6P36S tube's (in triode mode) plate resistance?
Is the Ri ca. 680 Ohm or 1KOhm?
Has anyone any useful info about this tube in triode mode? Triode curves, load lines, etc?
Greets:
Tyimo
"Replacing any coupling capacitors with a well designed and correctly matched driver or interstage transformer yields an almost shocking improvement in sound..." Peter Qvortrup
Old 26th January 2018, 07:54 AM   #1023
jazbo8 is offline jazbo8
jazbo8's Avatar
Google is your friend...
Old 26th January 2018, 10:07 AM   #1024
Thanks, but I know this one. It is from the Bartola Valves site.
I still don't know what is the plate resistance? 1K or 680R? Somewhere I saw the 680 Ohm value too.
Old 26th January 2018, 10:12 AM   #1025
jazbo8's Avatar
It’s clearly stated on the chart, Ra ~ 1k.
Old 26th January 2018, 10:30 AM   #1026
O.K. Thank you!
What about this? There is Ra:689Ohm
Old 26th January 2018, 10:36 AM   #1027
mogliaa is offline mogliaa  United Kingdom
mogliaa's Avatar
You can see that with the analogue curve tracer the Ra is estimated. The other value comes from the spice mode which is more accurate. As you know the Ra will vary at different points in the curve.
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp)
http://www.bartola.co.uk/valves/
Old 26th January 2018, 03:53 PM   #1028
O.K. I see.
Thank you!
Old 26th January 2018, 06:18 PM   #1029
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Originally Posted by smoking-amp View Post
Here are some triode mode curves
I'm throwing them all out.
You could use them as the pass element in a tube based regulator.
Old 11th March 2018, 11:53 PM   #1030
Perfectusaudio is offline Perfectusaudio  Australia
Originally Posted by PhilippS View Post
The circuit is inspired by the Synola 509 design and uses screen-driven PL519 (40KG6A) with fixed bias on g1.
-bias setting for 509 ?
Those Magnificent Television TubesHide this!Advertise here!
MOAK: The Mother of All Karlsonators (aka The Magnificent Monster) DeonC Subwoofers 126 23rd January 2015 03:35 PM
Television question... toptip Everything Else 6 23rd October 2012 06:50 PM
Surround sound amp, Sub woofer and television warrennyc Subwoofers 4 3rd January 2005 10:33 AM
distance from television ALFIrE Multi-Way 2 30th March 2004 06:46 AM
Television broken Bull Everything Else 3 21st January 2003 12:08 AM
