Those Magnificent Television Tubes
Old 5th January 2018, 08:19 PM   #1011
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Triodes, tetrodes, does not matter how you call them, if grids are made of one or 2 rods. They act deflecting beams.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 7th January 2018, 09:39 PM   #1012
Wavebourn's Avatar
You can see constant gm between -2 and -0.5V
Old 7th January 2018, 10:27 PM   #1013
Wavebourn's Avatar
This one has 2 control "grids":
Old 9th January 2018, 12:04 AM   #1014
piano3 is offline piano3  United Kingdom
what's it for this 1j37b?
Old 9th January 2018, 01:44 AM   #1015
Wavebourn's Avatar
It was used for frequency converters in superhets. 2 rods as "control grids", for intermodulation between 2 signals. But can be used as a CCS in the "constant gm" region of currents, as early suggested by Don.
Old 9th January 2018, 02:00 AM   #1016
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
anyine looked at the 954 pentode? looked linear too.,954 @ The Valve Museum
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 9th January 2018, 04:32 AM   #1017
Wavebourn's Avatar
Looks like an ordinary low current pentode, with variable gm. Pretty linear, though.
Old 9th January 2018, 03:45 PM   #1018
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
The 954 pentode was a WWII attempt at raising the maximum operating frequency of a conventional (non planar) vacuum tube by shrinking the guts. Of course this also reduces the voltage and power that can flow through it. It is basically a shrunken 6AK5 (5654) tube. There is a 7 pin miniature version, the 9001 that shares the same pinout as the 6AK5. I have some of those around here, but don't remember anything special about them.....maybe I'll try them again when I get back to ultra high gain circuits where microphonics become a problem.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 18th January 2018, 12:06 AM   #1019
TonyTecson's Avatar
@smoking-amp, do you have triode curves of the 6LU8/6LR8?
Old 18th January 2018, 05:16 PM   #1020
smoking-amp is offline smoking-amp  United States
smoking-amp's Avatar
Here are some triode mode curves for (the pentode of) a Montgomery Ward USA 6LU8 tube (looks like Sylvania construction, but measures closest to a GE 6LU8 I have)
Vertical 20 mA/div, Horiz. 50V/div, Grid1 4V steps down from 0V
I measured a Sylvania tube and was similar except 7% less Mu.
I measured a GE tube and was nearly identical.
I measured an RCA tube and that had higher Rp (the grid 1=0V line at 200 mA was at 150V plate instead of near 100V plate for the others.) Noticeable roll-over in the curves too. If the other 6LU8 RCA tubes I have measure like that, I'm throwing them all out.
Those Magnificent Television TubesHide this!Advertise here!
MOAK: The Mother of All Karlsonators (aka The Magnificent Monster) DeonC Subwoofers 126 23rd January 2015 03:35 PM
Television question... toptip Everything Else 6 23rd October 2012 06:50 PM
Surround sound amp, Sub woofer and television warrennyc Subwoofers 4 3rd January 2005 10:33 AM
distance from television ALFIrE Multi-Way 2 30th March 2004 06:46 AM
Television broken Bull Everything Else 3 21st January 2003 12:08 AM
