Those Magnificent Television Tubes
Old 1st January 2018, 02:49 AM   #1001
smoking-amp is offline smoking-amp  United States
smoking-amp's Avatar
Yep, 6AR8 is another BDT. Can make it amplify too. It is a full differential stage.
Here is a little blurb on BDT tubes and the 7763 from Shea's "Amplifier Handbook".
And some pics of the back side of the 7763 tube.
Old 2nd January 2018, 08:54 AM   #1002
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Originally Posted by smoking-amp View Post
the Tube Illuminati announces their best tube:
I am in.
File Type: jpg Screenshot from 2018-01-02 01-52-09.jpg (327.6 KB, 470 views)
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 3rd January 2018, 08:20 AM   #1003
hpeter is offline hpeter  Slovakia
hpeter's Avatar
these 2nd emission thingies are catching attention, but not sure how to use it
BLOG. XMOS_U8/PCM5102A > LL1544A > 6H9C+gyrator > 2A3_SOV/JJ > LL1660 > STAX SR207 _ SR L300 _ SR007 # LL2748 > 394A > LC 12H/1000
Old 4th January 2018, 12:05 AM   #1004
Some specific tube #s?
I think I did see something about a micro-channel multiplier amplifier recently. Secondary emission amplification. (night vision goggles, Tek image intensifier in 7104 scope...)
Maybe something available on Epay?
Old 4th January 2018, 12:27 PM   #1005
DIYBras is offline DIYBras  Brazil
DIYBras's Avatar
Originally Posted by Shef View Post
my bad, guys, I (as a semi-young crowds) do not have boxes of tubes in my stash, neither I have decades of experience with "those magnificients". ..<snip>
For UL usage, is possible to make a output trafo with separated screen grid windings:
https://www.plitron.com/wp-content/u...5/2100SSCR.pdf
http://toroid.com.br/images/download...d15f79b91b.pdf
See #TL70147
This is my baby (I designed it when I worked for Toroid do Brasil)
(of course, the datasheet have some marketing words and -6dB only graphs, but works very good).
They are expensive, so brave people will construct one.
How to make on TL70147 I don't show (unfortunately), but I can say that screen winding must closely follow the primary winding traject (for "normal" UL tap).
BTW for sweep tubes the 40% UL probably will cutoff/overload the tube prematurely due to famous high g2 gain. So perhaps 20% will be good. Easier to make.
Some years ago I found some russian vendors for these tubes by accident, in exploring all submenus and all products from seller. Some sellers don't identify correctly the name of tubes so is harder to find.
But I don't purchased any...
Photocathode Image intensifier tube V-8 EP33 night vision binocular goggle 1+gen | eBay
At least one found very easily.
Making cabinets for OLD projects (better later than never...)
Old 4th January 2018, 12:53 PM   #1006
hpeter's Avatar
it would be funny if that could be turned into ltp or phase splitter...
Old 4th January 2018, 01:11 PM   #1007
hpeter's Avatar
https://frank.pocnet.net/sheets/049/7/7360.pdf
higher sensitivity
Old 4th January 2018, 05:11 PM   #1008
Yes, 7360 was RCA's BDT. It got used for SSB in Ham radio designs. I have a small box of them. They were plentiful at one time, but have become scarce now. 6HW8 was Amperex's BDT, got a few of them. 6AR8 was Tungsol's BDT. 6JH8 was GE's BDT. 6ME8 another GE one. All of these are relatively plentiful, and all are similar to low Mu triodes over a CCS tail. I would say 6JH8 is the most practical one, and most plentiful, operates with deflectors at 0V DC.
No problem making them into a splitter. These also got used as voltage controlled gain controls (so remote control possible). These tubes can be easily configured to do analog multiplication too, using 3 of them in a tree configuration for highest accuracy. (they were used that way for SSB generation) They would have been the start of the next generation of tubes if SS had not come along. Many other related designs were in the research journals of the time. The beam deflection mechanism is a linear process (constant gm) as opposed to the 3/2 power process with conventional grids.
The available BDT tubes are not well suited to power stages, however, unless you have a lot of them. (I got a box of 330 6JH8s cheap during the sale days. A massive OTL? 6 Watts Pdiss per tube. Well a dozen tubes with an OT would be practical. Like two 36 Watt tubes.) Research BDT versions were approaching power capability in the journals. Since we have Twin/Crazy drive now, conventional Sweep tubes can fill that constant gm power role. Imagine a tube amp built -entirely- of linear gain devices.
The proverbial "wire with gain".
Old 5th January 2018, 07:20 AM   #1009
Wavebourn's Avatar
In USSR miniature tubes with deflecting rods were used in military applications.
Old 5th January 2018, 08:58 AM   #1010
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
Are these really beam deflecting tubes or just small signal beam tetrodes, such as Raytheon's 5678?
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
Those Magnificent Television TubesHide this!Advertise here!
MOAK: The Mother of All Karlsonators (aka The Magnificent Monster) DeonC Subwoofers 126 23rd January 2015 03:35 PM
Television question... toptip Everything Else 6 23rd October 2012 06:50 PM
Surround sound amp, Sub woofer and television warrennyc Subwoofers 4 3rd January 2005 10:33 AM
distance from television ALFIrE Multi-Way 2 30th March 2004 06:46 AM
Television broken Bull Everything Else 3 21st January 2003 12:08 AM
