SET output impedance vs speaker impedance
Old 20th April 2012, 04:41 PM   #1
Arno Pf is offline Arno Pf  Netherlands
Default SET output impedance vs speaker impedance
Besides and effect on damping factor and output power I would like to know what the experiences are regarding (mis)matching SET output impedance w.r.t speaker impedance.
For example 8Ohm out driving 16Ohm loudspeaker increases damping factor and reduces output power bit what are the experienced differences in sonics (I am asking since my amp requires soldering to change the impedance so quick comparison is no option)
Thanks in advance
Arno
Old 20th April 2012, 06:17 PM   #2
dsavitsk is offline dsavitsk  United States
dsavitsk's Avatar
The 8 Ohm tap on your OPTs does not imply an 8 Ohm output impedance. If your transformers are 3.5K:8, since the rp of a 300B is ~800 Ohms, the Zout is ~1.8 Ohms + the impedance added by the transformer (usually a few Ohms.) The 8 Ohm tap indicates where a to connect an 8 Ohm speaker in order that it reflect the load you are expecting.
As for mismatching, it depends largely on whether the transformer is up to the task.
Old 20th April 2012, 07:05 PM   #3
This was understood..still the question is remaining what the experiences are regarding difference in sound....any experience on this?
Old 20th April 2012, 07:37 PM   #4
dsavitsk's Avatar
It depends on several factors, such as whether your transformers have enough inductance, how damping factor impacts your speakers, etc. I've had it work well, and badly, and how it will work in your case is dependent on your amps and speakers.
SET output impedance vs speaker impedanceHide this!Advertise here!
Speaker impedance vs output power kubeek Multi-Way 10 2nd May 2011 08:25 PM
My gainclone set up and impedance mismatch? spacemen12 Chip Amps 7 29th August 2009 07:12 PM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 05:17 AM
Need help understanding transformer impedance ratios and impedance matching percy Tubes / Valves 5 28th February 2005 08:35 PM
Speaker impedance roughly 6 ohms, 2A3 SET... Saurav Tubes / Valves 14 17th October 2004 03:47 PM
