Help with layout of tube preamp - diyAudio
Old 20th April 2012, 04:27 PM   #1
JFace is offline JFace  Canada
Default Help with layout of tube preamp
Hi folks,
I thought I would post a preliminary layout (conceptual) for a mic/instrument preamp that I'm designing. Without going into the details of the circuitry, can you critique my layout of components?
Thanks for your time.
Old 20th April 2012, 07:24 PM   #2
dsavitsk's Avatar
The layout seems OK. Keep in mind that the heater supply is going to need some big caps, and that the heater reg is likely to dissipate a lot of heat. Additionally, for a mic pre, I'd add a B+ regulator -- even something as simple as a zener + a pass transistor will save space and work wonders.
Can someone please check my PCB layout for this preamp? GregH2 Tubes / Valves 3 19th January 2010 11:22 PM
preamp layout suggestions please gary h Tubes / Valves 4 6th October 2008 01:20 AM
preamp layout and hum problems - help! Tex Houston Solid State 1 11th June 2007 10:44 AM
Tube preamp question...also, chassis layout jim_vt Tubes / Valves 1 22nd January 2006 01:01 AM
Preamp PCB layout. Fritzell Solid State 10 26th September 2005 07:40 PM
Copyright 1999-2017 diyAudio
