Designing a Tube Rectifier Circuit
Old 18th April 2012, 04:58 AM   #1
Ducs is offline Ducs  Canada
Default Designing a Tube Rectifier Circuit
I am trying to design a tube rectifier circuit for my upcoming tube project. I am doing lots of research and so on. I will be using a 6BY5G rectifier tube. I came across a 'hybrid bridge rectifier' - like th eone in the pic below:
Are there any benefit of using that type of a circuit ??
Old 18th April 2012, 06:16 AM   #2
Miles Prower is offline Miles Prower  United States
Miles Prower's Avatar
There are a few: you don't require a center tapped secondary, you get the full utilization of the secondary voltage, and it's fewer holes you need for the chassis, less heater power, and no problems with Vhk issues since you're substituting Si diodes for hollow state diodes.
Back in "the day", bridge power supplies would typically use something like a 5U4 for the positive rail, and two TV damper diodes for the negative. These being used with a center tapped secondary to implement "economy" power supplies, mainly for plate power and screen power for higher powered amps (audio or RF). A center tapped secondary also provides a ready source of both positive and negative rails.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 18th April 2012, 01:36 PM   #3
jamesdb is offline jamesdb  United States
If you use a center tapped transformer with a tube rectifier then you don't need the hybrid design/2 diodes. I think you would only use a hybrid if you happened to have a non-center tapped transformer on hand to use and wanted tube rectification, or if there was a non-center tapped transformer (possibly a toroid) you wanted to use, most likely because it is cheaper than a center tapped transformer. If you are on a real budget, Antek has some nice toroids with electrostatic screens and magnetic shields that are considerably cheaper than most center tapped transformers and could be used with a hybrid design.
Old 18th April 2012, 07:35 PM   #4
tomchr is online now tomchr  Canada
tomchr's Avatar
The Antek transformers can be used with the regular tube rectifiers as well. They don't have center tapped windings, but they do have two separate windings. If you wire them correctly in series, you'll end up with the equivalent of a center tapped winding.
The only catch is that some of their transformers have bias taps at 70 V or so. Unfortunately, the windings are identical (not symmetric) so you'll end up with, say, 400-70-0-330-400 rather than 400-70-0-70-400 V. This is only an issue if you plan to use the 70 V tap, of course.
Note, however, that by the time you get the transformer and the cover bell, the solution cost is about as much as a typical Edcor transformer. The Edcors are a lot prettier... But E-I rather than toroid. Tradeoffs, tradeoffs.
~Tom
Modulus-86: 40W/8Ω @ 0.000061% THD. HP-1: 3W/20Ω, 450mW/300Ω @ 0.000032% THD. DG300B and Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Designing a Tube Rectifier CircuitHide this!Advertise here!
converting tube rectifier to solid state rectifier. tubo Tubes / Valves 26 24th December 2009 01:12 AM
help designing a Linkwitz Transform circuit blrh93 Full Range 4 4th November 2008 12:59 AM
Printed circuit board designing? flyinglemur Tubes / Valves 11 23rd March 2008 01:41 AM
Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? zxx123 Tubes / Valves 4 21st February 2005 05:02 AM
PCB layout n circuit designing tanvicarrier Parts 0 12th August 2004 05:22 AM
