Bogen RP40A transformers....what to build with them?
Old 2nd May 2012, 02:06 PM   #121
rongon is offline rongon  United States
rongon's Avatar
Originally Posted by TheGimp View Post
I would worry about the negative supply for the current source. At power up there will be no voltage there. Current can't flow through the return diodes from ground to the transformer windings as they are in opposition to the negative supply diodes.
Once everything starts conducting, there will be a current path through the current source, through the LTP and back, however I doubt the minus supply will ever function properly.
Thanks for bringing this up. I'm actually glad to see someone is checking our thinking for mistakes.
Why exactly wouldn't the minus supply function properly, at least once the 6DJ8 is warmed up and conducting?
Would a plain old resistor down there in the LTP tail present the same problems? Small signal diodes could be used between grids and cathodes of 6CG7 to keep the cathodes close to ground potential, and therefore close to the heaters' potential (to keep from exceeding peak heater-to-cathode voltage ratings).
I found that triode current sink described in a couple of well-regarded texts, and I know JC Morrison used it in an amp from the Fi Tube Audio Primer (the PP 807 amp, I believe). So I'm curious where I went wrong with this implementation. Any way you see to save it?
How about a husky damper-diode tube rectifier in series with the B+ to act as a soft-start? (Or a paralleled-plate 5U4 perhaps?)
The idea was to find a way to use up the tube in that extra 9-pin socket. I'm not married to the idea, but it seems to me that it ought to work.
Old 2nd May 2012, 02:15 PM   #122
deicide67 is offline deicide67  United States
Hi Ron,
If I am reading the "caution" correctly, there is really only a warmup issue, so I could easily implement a delay circuit to allow the heaters and bias voltages to come up before the B+ are dropped.
What do you think?
Blair
Old 2nd May 2012, 02:43 PM   #123
TheGimp is offline TheGimp  United States
TheGimp's Avatar
I believe it will never work, as the diodes used to produce the -V supply are in parallel with the diodes to ground. Therefore, the cathode connection of the current source ties to ground.
You need another winding (or transformer) to produce the V- supply.
Old 2nd May 2012, 02:52 PM   #124
Hi Gimp,
That makes sense. I do not have room for another transformer.
As Ron pointed out a while back in the thread, the LM334Z has a current rating of 10mA, so it is not optimal. What about larger devices like the LM317 wired as a current regulator?
As Ron said, it is really a matter of us trying to use all available triodes here, but nothing that is mandatory.
I'd actually prefer to not have to try to fit another supply in here.
Also, is there not a way to use the triode strapped like the example here as the current sink/shunt to ground vs. a negative plate supplied CCS?
The Valve Wizard
Thanks guys!
Blair
Old 2nd May 2012, 05:04 PM   #125
rongon's Avatar
I figured the transformer is 225V-0-225V under load. But that's really only a guess.
You can certainly use an LM317 as the CCS for the 6CG7. However, the LM317 has a max voltage rating of 37V, so you would need a much lower negative voltage rail for that. You have that 90VAC winding to work with, right?
However, as many here will be quick to point out, the LM317 is not the best performing device for use as a CCS. Its (desirable) ultra-high impedance degrades as you go up in frequency, starting at about 10kHz. However, it's still probably no worse than a triode would be.
The feature of the LM317 that makes it recommendable is that it is so easy to use. To find the set resistor value for the current you want, you simply take the LM317 reference voltage of 1.25V divided by the current you want. So 1.25V / .014A = 89.29 ohms. 91 ohms would be close enough (rearranging the preceding, 1.25V / 91R = 0.01374A, or 13.74 mA).
A 10M45S or DN2540 depletion mode MOSFET is better for use as a CCS, and better yet would be two of these devices in a cascode. These devices are good for voltages up to 400V, so there's no reason not to use them, except...
The only reason not to use one of these depletion mode MOSFETs is that finding the proper resistor value to set the current you want might be tricky, because like most transistors, these devices characteristics can vary over a wide range. You can use a small multiturn pot to dial in the desired current, but pots are less reliable than fixed resistors. Paralleling resistors to make the correct value can be a bit fiddly, but if you don't mind going through that extra effort, that's the way to do it.
If you start using these devices, you could use one in the plate of the 6DJ8 (as a constant current *source*, instead of a *sink*) and get even better performance from that part of the circuit.
Now you've got some silicone in your tube amp, but it's getting slicker -- if that's the direction you want to go in. And now you've got half a 6DJ8 you're not using.
Again.
Old 2nd May 2012, 05:12 PM   #126
Hi Ron,
I know this leaves an unused 1/2 6DJ8 per channel, but it does simplify things to an extent.
Now for the dumb questions. Why can't I just use the LM317 like the 334Z in this circuit?
http://www.diytube.com/st70/diytube_st70_B.pdf
No neg voltage required?
I found a current regulato calculator for the 317 and 90 ohms gets me 14mA.
LM317 / LM338 / LM350 Voltage and Current Regulator Calculators Just in case you want it.
Am I missing something?
Thanks,
Blair
Old 2nd May 2012, 05:16 PM   #127
I ado have a bunch of irf9610s laying around. I do not know where they came from, but I've seen transistor sinks on tubes before.
Blair
Old 2nd May 2012, 05:52 PM   #128
rongon's Avatar
Originally Posted by deicide67 View Post
Hi Ron,
Thanks,
Blair
No, you got it. 91 ohms = 13.74mA, 90 ohms = 13.89mA. No negative voltage required.
91 ohms is an off-the-shelf resistor value, which is why I mentioned it. 90 ohms could be made by paralleling two 180 ohm resistors. Whichever you prefer.
The problem with running the LM317 straight from the 6CG7 cathodes to ground is that the LM317 needs a couple of volts across it to operate. If the 6CG7 is overloaded and is driven close to grid current, the bias would go close to 0V and the LM317 would stop conducting. The distortion would be spectacularly horrible. So I like to see it used with more like +5 or +6V minimum Vgk for the 6CG7's.
Try the LM317 with a set resistor of 91 ohms and see what voltage appears at the 6CG7 cathodes. If it's higher than +4V to ground, then I think it'll be OK. If it's lower, then you should increase the value of Rset to 100 ohms. That will put 6.25mA on each 6CG7 triode (about 12.5mA combined).
BTW, that 12AU7 LTP used with an LM334Z in the tail would not be as nice as a 6CG7 with more current going through it. 6CG7 and 12AU7 will bias up just about the same, but 6CG7 has lower distortion to begin with, and getting the current closer to 8mA per triode reduces distortion further. Better sound should result.
Old 2nd May 2012, 05:55 PM   #129
rongon's Avatar
That's an enhancement mode MOSFET, no? Not as easy to wire up as a depletion mode MOSFET for use as a CCS, and the DN2540 or 10M45S are not at all expensive. (Like $1.20 ea or so)
Old 2nd May 2012, 06:04 PM   #130
Thanks,
Not sure why I have the irfs. No worries.
I will try the 317 with 90 ohms to ground and let you know what I have on the cathodes. I think it will be OK. I can push the bias up to 8mA per triode if you think that is better?
Blair
Bogen RP40A transformers....what to build with them?Hide this!Advertise here!
how to build a pre using S&B TX-102 transformers krishu Parts 296 30th April 2014 11:39 AM
WTB: bogen db110 transformers/ transformer tubo Swap Meet 0 11th January 2008 12:54 PM
Bogen help sickss Tubes / Valves 0 2nd June 2004 01:25 PM
Looking for transformers to build +5V, +12V power supply for CD-ROM drive Saurav Parts 4 19th September 2003 02:21 PM
Copyright ©1999-2017 diyAudio
