Hiraga's Improved Concertina Phase Splitter - diyAudio
Old 16th April 2012, 03:58 PM   #1
Tubologic's Avatar
Default Hiraga's Improved Concertina Phase Splitter
I found this circuit in an old French "L'Audiophile" book describing a PP amp designed by Jean Hiraga. The circuit looks conventional, except for the phase splitter which (the author claims) is an "improved" version of the classic Concertina (aka split load or cathodyne) circuit. The "improvement" consists in the addition of a single resistor connected between plate and cathode of the splitter tube, which looks like positive feedback to me. I've never seen this circuit used anywhere and am wondering what are the real advantages (if any) of this circuit in comparison with the classic Concertina phase splitter. I breadboarded this circuit and confirmed it is stable and works quite well, though I didn't measured all the electrical spec's yet.
Any thoughts ?
Old 16th April 2012, 04:09 PM   #2
Merlinb is offline Merlinb  United Kingdom
Merlinb's Avatar
Since it's directly in parallel with the triode it effectively becomes a portion of ra, so I suppose you could argue that it has a linearising effect on ra. But it also reduces the effective gm at the same time, so I would question its usefulness. Maybe its meant to improve recovery time from blocking distortion?
Old 16th April 2012, 04:47 PM   #3
Tubologic's Avatar
Here's what the author says regarding the improvements (translated from original french text):
... we can use three resistors of the same value, in this case it looks like the input voltage is increased by 33% and the loads multiplied by 66% from their initial value. Consequently, this will increase the gain (which is between 0,7 to 0,9 for a classic Concertina) to a value close to 2 (when µ raise), as well as an increased bandwidth...
I understand the increase in gain (a side effect of any P.F) but the positive effects on the frequency bandwidth is less clear to me.
Old 16th April 2012, 04:56 PM   #4
SY's Avatar
If you get blocking between the cathodyne and the following voltage amp, the design is severely flawed. The circuit already has 100% feedback, so this won't really linearize it-in fact, since it effectively makes the loadine more vertical, I would expect distortion to be higher. (Remember, the outputs at plate and cathode are equal and opposite, so the center of that resistor is at ground) I am doubtful that the gain increases to 2.
I wonder if this is one more case of trying to fix a non-existent problem...
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 16th April 2012, 05:50 PM   #5
DF96 is offline DF96  England
Think what a gain of 2 will mean. You raise the grid by 10V, and the cathode goes up 20V. The grid-cathode voltage has shifted by 10V. Do you really want your phase splitter staggering between cutoff and grid current? This is a daft idea. Why am I not surprised?
And when did positive feedback increase bandwidth and reduce distortion?
Old 16th April 2012, 05:57 PM   #6
SY's Avatar
Maybe he means that the gain from cathode to plate is 2? Either way, this is not positive feedback, it's just an extra load to drive.
Old 16th April 2012, 06:13 PM   #7
Tubologic's Avatar
Seems logical to me too.
Never. PF usually has a detrimental effect both on distorsion and bandwidth.
Old 16th April 2012, 06:17 PM   #8
directdriver's Avatar
That looks like it. Since it's connected to the two opposing phases before the caps and input resistors to ground, will this have any effect in canceling distortion, like some crisscross circuits a la early Audio Research? Or it reminds me of an input transformer with no center tap secondary and shunting it a resistor and then a pair to ground which I saw that in some circuits. I have no idea, just speculating. It is interesting though.
Old 16th April 2012, 06:18 PM   #9
SY's Avatar
It's not even that. It's an extra load, no more, no less.
Pretend the 39k resistor is two 19k5 in series. At their junction, the voltage is zero. So the effect is the same as paralleling the plate and cathode loads with 19k5 each.
Old 16th April 2012, 06:21 PM   #10
Tubologic's Avatar
Nevertheless, JH wrote (p.14):
... (la résistance) introduisant de la sorte une réaction positive de tension,...
which means:
... (the resistor) introducing in this way a positive voltage reaction...
Phase Splitter Help famousmockingbird Tubes / Valves 16 10th May 2011 09:40 PM
Need help on phase splitter guwakzhai Power Supplies 7 23rd December 2010 05:51 PM
Concertina Splitter question - Need help alexage Tubes / Valves 20 2nd June 2010 01:39 AM
Is this a phase splitter? tom-vdl Solid State 9 15th October 2009 08:21 PM
Diff amp input cap for improved phase margin pooge Solid State 47 14th July 2007 09:11 AM
Copyright ©1999-2017 diyAudio
