Hiraga's Improved Concertina Phase Splitter
Old 16th April 2012, 06:22 PM   #11
Yvesm is offline Yvesm  France
Yvesm's Avatar
Because of the DC coupling with the previus stage, this resistor just reduces the idle current in the PI by some 3 mA and, yes, at the expense of an extra load.
Gain is more probably halved than doubled.
Comprend pas / Can't understand . . .
Yves.
Old 16th April 2012, 06:23 PM   #12
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
It is an extra load independent on grid currents of output tubes. It decreases linearity of the stage that is somehow compensated by global negative feedback, no big deal, but when the amp is overdriven it sounds les nasty as the result.
I.e. it is the way to make the amp little worse in normal conditions, and less worse when overdriven.
All author's explanations sound like marketing speech to me, total nonsense mixed together from technical words.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 16th April 2012, 06:23 PM   #13
On Hiatus
SY's Avatar
Originally Posted by Tubologic View Post
Nevertheless, JH wrote (p.14):
... (la résistance) introduisant de la sorte une réaction positive de tension,...
which means:
... (the resistor) introducing in this way a positive voltage reaction...
He was wrong.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 16th April 2012, 06:28 PM   #14
Wavebourn's Avatar
Originally Posted by SY View Post
He was wrong.
Not completely. Feedback becomes positive when upper load hit grid current of output tube, i.e. resistance of anode load becomes less than resistance of cathode load. In all other conditions it is just a shunt.
Old 16th April 2012, 06:30 PM   #15
On Hiatus
SY's Avatar
The phase splitter couples to a driver tube, not the output stage.
Old 16th April 2012, 06:30 PM   #16
DF96 is offline DF96  England
Yes, when all is balanced (the ideal case) it will increase the load while simultaneously reducing the quiescent current in the valve. Guaranteed recipe for increased distortion?
Maybe he means that the gain from cathode to plate is 2?
Surely he can't mean that, because he compares it with the normal case of 0.7-0.9 which is clearly from grid to cathode. I suspect he has misapplied the feedback equation, or something similar. It is easy to get a daft answer by blindly plugging things into a formula.
To get useful positive feedback from anode to cathode you need a transformer. I won't say any more because I don't want to resurrect an old debate!
Old 16th April 2012, 07:41 PM   #17
Wavebourn's Avatar
So, in this particular case it was a cliche. I.e. result of generalizing of something that was useful in certain context. It happens very often, in electronics design it is called Rule of Dumbs. Like, shunting of electrolytic cap by a film one with 10% of capacitance, like Zobel networks in output of transistor amps, and so on, including whole topologies that are suboptimal in many cases except certain ones.
Hiraga's Improved Concertina Phase SplitterHide this!Advertise here!
Phase Splitter Help famousmockingbird Tubes / Valves 16 10th May 2011 09:40 PM
Need help on phase splitter guwakzhai Power Supplies 7 23rd December 2010 05:51 PM
Concertina Splitter question - Need help alexage Tubes / Valves 20 2nd June 2010 01:39 AM
Is this a phase splitter? tom-vdl Solid State 9 15th October 2009 08:21 PM
Diff amp input cap for improved phase margin pooge Solid State 47 14th July 2007 09:11 AM
