About 6AS7BTL Amp - diyAudio
Old 15th April 2012, 09:25 AM   #1
MCLL is offline MCLL  Hong Kong
MCLL's Avatar
Default About 6AS7BTL Amp
Hello everybody,
I have TWO questions for attached 6AS7BTL schematic.
How much this amp output?
What is the best speaker for this amp such as 4ohm, 8ohm, 16ohm or 32ohm?
Cheers
MCLL
Old 15th April 2012, 11:49 AM   #2
As much as possible - as for all OTL designs.
Depends mainly on the load impedance - as for all OTL designs.
Best regards!
Old 15th April 2012, 07:22 PM   #3
Wow, that amp actually looks really simple! What topology is it? Potentially, would you need a specific load for it or a most efficient value?
Old 15th April 2012, 09:52 PM   #4
Miles Prower's Avatar
"H" Bridge: you usually see something like this implemented with MOSFETs, and operated as a Class D amp. Not so much as an audio stage, as it has the same problem as any stacked design: one half operates as a cathode follower, and the other as a grounded cathode stage, with unequal voltage gains, and inherent imbalance. (No "P-Channel" VTs available.)
You'll get the best performance by running it with the load it was designed to accommodate.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 15th April 2012, 10:44 PM   #5
kevinkr's Avatar
I really wouldn't go below 32 ohms with this design... (And that is likely to be marginal)
You could parallel additional 6AS7G, but would have to match them carefully and getting them to current share might be tricky. Another alternative would be the 6336/A/B/C. Depending on available drive a quartet of 6C33 might get you some real power.
Edit: On second look the implementation of the feedback loop is questionable.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
FS- Twisted Pear Buffalo 32S Board & System New & Unused secretriches Swap Meet 1 10th August 2009 03:17 PM
Modify & build out (2) Western Electric 300B / 2A3 Hammond monoblock amps & UTC LS-5 quality sound Tubes / Valves 0 9th May 2009 04:59 PM
Krell KSA 80 bias & dc offset check & adjust procedure Clouseaupte Solid State 3 9th August 2007 10:39 AM
DIY-AMP <ZAS> Low THD & IM high bandwith murphy Solid State 18 30th December 2005 11:28 AM
Copyright 1999-2017 diyAudio
