Silly basic layout question - AC heaters
Old 15th April 2012, 01:33 AM   #1
rongon is offline rongon  United States
rongon's Avatar
Default Silly basic layout question - AC heaters
I was just about to start wiring when I noticed this...
A picture is worth a thousand words, so there's a pic attached.
Is "A" a really wrong way to wire up four tube sockets for parallel AC heaters?
Is "B" the only way it should be done?
The problem I have is that I would like to put an input jack right above ("north" of) V3, but I'm worried about the heater twisted pair passing right near the back of that jack.
Or should I be more worried about the "open" ends of the heaters on V2 and V3 in "A", which would expose the input jack to the AC field?
Old 15th April 2012, 01:45 AM   #2
DigitalJunkie is offline DigitalJunkie  United States
Send a message via AIM to DigitalJunkie
I'm not sure it matters much..They are pretty similar.
I would probably go with "A",just to keep the (horizontal) wires between V1/2 and V3/4 further away from the input jack wiring.
Old 15th April 2012, 01:46 AM   #3
trobbins is offline trobbins  Australia
trobbins's Avatar
"A" is fine. You can even go star from V1. The impact is not just separation distance, and twist, but also the amount of current in that pair.
Old 15th April 2012, 01:52 AM   #4
kevinkr's Avatar
The most important thing is to try and minimize the untwisted loop area around the sockets and either case as shown seems to do this fine.
Personally I prefer A as it would slightly reduce the filament voltage drop to the remaining two tubes - probably not enough to be worth worrying about.
The only real issue IMHO is not to put too many wires on the socket pins such that they are not mechanically solid prior to soldering. (How many of us have done/do that... Guilty.. )
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 15th April 2012, 02:10 AM   #5
rongon's Avatar
Thanks to all!
Fortunately, V1 and V2 are octal sockets with nice, hefty solder tabs.
V3 and V4 are 9-pin minis. There will be 900mA going to that branch.
Also, that input jack may be a balanced 1/4" phone jack (nice old Switchcraft part). That should reject hum well too.
I'm glad I can do "A". I was hoping that would be the consensus.
Old 15th April 2012, 03:12 AM   #6
nazaroo is offline nazaroo  Canada
Banned
Originally Posted by rongon View Post
Thanks to all!
You won't get much hum resistance from the jack if its on this side of the topplate.
To get significant results in shielding input wires,
try using a mini-coaxial cable from the jack right to the first input tube, and star ground that shield to a good central ground around the early stage(s). Then floating the jack will be significant.
For the heaters, physical layout is critical:
BAD LAYOUT:
BETTER LAYOUT:
COMPONENTS WELL AWAY FROM AND AT RIGHT ANGLES TO HEATERS
Old 15th April 2012, 05:03 AM   #7
rongon's Avatar
Thanks for the tips. I think my wiring is not so bad as the first picture. That's pretty wretched.
I'm not sure if it was clear from what I wrote, but I was thinking of making the input to this amp fully balanced, as in push-pull differential. That's what the 3-conductor phone plug would be used for. I know XLR's would be way better, but I already have the cables made up. And really, how bad are 3-conductor 1/4" compared to (yeesh) RCA phono connectors?
Silly basic layout question - AC heatersHide this!Advertise here!
basic bridge rectifier question.. ac on output wicked1 Power Supplies 6 10th September 2009 12:36 AM
AC wiring heaters, A or B ? zigzagflux Tubes / Valves 10 4th July 2008 10:43 PM
Very basic -- and maybe silly -- differential-pair question Onvinyl Solid State 9 1st February 2006 06:46 PM
Basic theory question: effective AC voltage Devil_H@ck Parts 2 18th June 2004 11:24 AM
Help with hum in AC heaters HeadSh0T Tubes / Valves 21 27th September 2003 01:40 AM
