Gyrator Filter
Gyrator Filter
Old 14th April 2012, 05:49 PM   #1
BRSHiFi is offline BRSHiFi  United States
Previously known as kingden
Default Gyrator Filter
http://www.triodeel.com/images/b9b.gif
The filters for this EQ look like a type of gyrator. Does anyone know the equations on how to calculate the resistor and capacitor values based off of Fc and Q?
The only reliable gyrator source I was able to find used opamps which are easy enough to work with, but nothing for tubes.
Old 14th April 2012, 07:11 PM   #2
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Gyrator Filter
So what is the difference?
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 14th April 2012, 07:14 PM   #3
The inverting and non inverting inputs are both used.
http://upload.wikimedia.org/wikipedi...mp_Gyrator.svg
Old 14th April 2012, 08:13 PM   #4
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Gyrator Filter
thought I had seen another thread
Tone controls
Old 15th April 2012, 12:19 AM   #5
Simon B is offline Simon B  United Kingdom
Both inputs are shown as being used, and the diagram is a bit ic specific. The op-amp is wired as a unity gain voltage follower, with hi-z in, lo-z out.
Perhaps this might help:
The voltage follower can be implemented with valves, transistors or ic op-amps. This also applies to operational amplifiers.
Old 15th April 2012, 03:04 AM   #6
Guitar Pedals: Gyrator Filter Calculator
I found a calculator here for determining the values of the center frequency and Q factor. Anyone know what the equations are?
I know that:
- The amplifier, R, and C substitute for an inductor. Each inductor has a Q factor. This can obviously be influenced by R and C for a synthetic inductor.
- RL is the series resistor for the inductor substitute.
- center frequency = BQ
- L = Rl * R * C
Gyrator FilterHide this!Advertise here!
Help with gyrator mogliaa Tubes / Valves 61 9th April 2012 05:01 PM
