Old 14th April 2012, 02:26 PM   #1
wicked1 is offline wicked1  United States
wicked1's Avatar
Default Did I break my tube? (new blue glow)
I was swapping tubes in my amp, and dropped a 307a(vt-225) a foot or two. It was still in its box and bubble wrap. When I opened it, the metal plate cap was off. The wire inside still fine. I was able to scrape off some dried glue and push the cap back on. It seems to have made a solid contact. I put it in and biased up the tubes.
All sounds great, bias stable. But, the tube I dropped has blue glow around the top.. right where the glass restricts at the top.
I've seen other tubes that were fine glow this much.. But the fact it didn't glow before has me concerned.
so basically, did I break it, or is it possible things got a little misaligned when it fell, so new sections of glass are being struck by electrons? (maybe the plate slid down a bit, or something.. I'm just guessing, hoping I didn't kill my tube..)
If I did somehow break it, what's the likely failure mode? Basically, can I use it until it dies or glows to a disturbing level, or should I just remove it to keep my amp safe?
Thanks for any advice.
Old 14th April 2012, 03:10 PM   #2
Unless the getter turned white, you still have a good seal. What you are seeing is coronal arcing.
Tube Blue Glow question wangmauler Tubes / Valves 13 27th May 2011 08:58 AM
blue glow, how? newtube Tubes / Valves 46 18th April 2010 07:12 PM
Blue glow in tube. Is the tube dead or not? Pentium100 Tubes / Valves 37 22nd October 2009 06:45 PM
Blue glow confused :( bobhayes Tubes / Valves 50 20th January 2007 05:00 PM
Blue Tubes the glow jleaman Tubes / Valves 34 6th August 2002 11:07 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
