Old 25th April 2012, 04:36 AM   #51
rmyauck is offline rmyauck  Canada
Those coupling caps should be a nice upgrade, where you should hear the difference in that place. I haven't had the funds to try more expensive caps so I don't know how different ones sound., but I did read they are well liked. You could also try .22 uF of the same voltage too for maybe extended frequency response.
It's also good too add (4) 100 ohm screen grid resistors to the parts list for installation of one each at pin #4 of the output tubes to the OPT transformer leads. This will help the output tubes last with the added capacitance in the PS.
Randy
Tube amp kit and speaker recommendations? mrcandyman Tubes / Valves 19 23rd December 2011 03:41 PM
Recommendations for a valve amp kit Fivetide Tubes / Valves 13 6th August 2011 12:43 AM
power amp kit recommendations keungfai Tubes / Valves 11 17th August 2006 01:22 PM
Amp kit recommendations DaveCan Tubes / Valves 22 2nd August 2006 12:32 PM
1st amp (and preamp) kit recommendations ? greg7 Solid State 1 20th April 2003 12:56 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
