high voltage after cap. change - Page 2 - diyAudio
Old 13th April 2012, 06:00 PM   #11
andrew; 1000 vdc. 750 vac
Old 13th April 2012, 06:06 PM   #12
MelB is offline MelB  Canada
Cowboy, leave the standby OFF. Measure the voltage on pin 5 of the power tube (6L6). Try to get that voltage up over -40 volts. There should be a pot to adjust.
Old 13th April 2012, 06:51 PM   #13
the ab165 circut uses a pot to minomize hum it only bias's one tube, right now i have -30 vdc coming off the board
Old 13th April 2012, 07:03 PM   #14
the best i can get on pin 5 is 29.9 on one, 24.9 on other 6l6. one is adjustable the other is not. how do i raise the voltage on both of them?
Old 13th April 2012, 07:38 PM   #15
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Yes.
Old 13th April 2012, 07:44 PM   #16
the voltages i quoted should have been -24.9 and -29.9 at pin 5 sorry. would this indicate a bad resister or capacitor.
Old 13th April 2012, 08:21 PM   #17
TheGimp's Avatar
Measure them for AC voltage. It should be in the very low mV range. If not you may have a cap problem.
If the AC voltage is in the low mV range, then I would expect the problem to be in the resistors.
Old 13th April 2012, 09:40 PM   #18
Is the resistor going to ground in the bias circuit measuring 15K?
Old 13th April 2012, 09:41 PM   #19
Or is the cap in backwards there? The positive goes to ground in the bias.
Old 14th April 2012, 03:46 AM   #20
the bias board resister is 470 ohm 1watt off 1 diode, cap is 50uf-50v off same line to + ground. both are new.
why this class D power supply no high voltage side electronic cap? greenamp Class D 10 29th January 2012 05:32 PM
pg ms2125 showing right clip after cap change! marko Car Audio 11 28th May 2007 06:40 AM
Cello Palette voltage change? young_pup Solid State 3 27th September 2006 10:23 PM
Change coupling cap from .47uf to 2.2uf andy2 Tubes / Valves 7 24th February 2005 04:40 PM
Voltage Change US/UK ebarker2 Solid State 5 22nd February 2004 04:24 PM
Copyright 1999-2017 diyAudio
