Transformer data required P782
Old 11th April 2012, 11:19 PM   #1
mosfetmaniac is offline mosfetmaniac  New Zealand
Default Transformer data required P782
I have a pair of Dyanco Mk2 amps, one is 230v and one is 120v and I wanted to convert the 2nd amp to 230v operation.
Does anyone have the turns ratios and wire diameters for the P782 or data for a 230/240v model?
I believe there is a 240v transformer available in the US but freight nearly triples the price and I'd rather recycle the laminations as they are in good condition.
Thanks in Advance.
MM
all sorts of stuff
Old 12th April 2012, 06:19 AM   #2
JohnTubeamp is offline JohnTubeamp  Cyprus
Hello,
Do you plan to rewind the transformer by your self? If yes, then you have to dismantle it carefully and count the turns of each winding. Make sure to make a diagram and write down all the details.
Old 13th April 2012, 06:00 AM   #3
I'll have to get someone to wind it for me as I don't have the gear, patience or time. The guy winding it doesn't either so the winding data would be superb :-)
all sorts of stuff
Transformer data required P782Hide this!Advertise here!
Help required on Logitech Z-2300 toroidal transformer RishiGuru Parts 42 18th January 2017 01:17 PM
Transformer Data oldschooltube Tubes / Valves 2 18th July 2011 01:20 AM
LM1875, size of EL-Transformer required dozeone Power Supplies 1 29th December 2009 09:45 PM
Tda 7386 Spice Data Required rehanabid Chip Amps 9 3rd May 2007 07:25 AM
