what is a good CCS in the cathode of a 6V6 amp ? Probably trying blumlein/gartner solution with ccs
#2 |
CCS in cathode of pp amp will limit you to class A with it's lower power output capacity. That said, you should get 8W depending on B+. I consider 8W quite sufficient and don't see it as a problem.
The Why a current source? Are you driving only one grid? If so, the CCS will limit the drive as it will have a minimum voltage across it before it goes out of regulation. 30mA per tube? I don't think a discrete current source will have a lower dropout than an LM317 as a current source. The LM317 has reasonable noise numbers, so I'd go with it. |
#3 |
I agree that a LM317 regulator is adequate in this roll. I have used them extensively and they worked fine. Zener protect and consider HV versions if going DC coupled. Others have reported improvements with cascade mosfet CCS but I doubt the benefit is worth it.
Shoog |
| Monster Two-Chassis 6V6 PP amp | pjanda1 | Swap Meet | 0 | 11th April 2012 02:40 AM |
| Finished my first PP amp, 6SJ7-6SN7-6v6 | athos56 | Tubes / Valves | 23 | 7th August 2010 07:26 PM |
| New Schematic - PP UL 6V6-types, CCS-fed | sorenj07 | Tubes / Valves | 29 | 5th August 2009 07:56 PM |
| For Sale another 6V6 PP tube amp | Sal Brisindi | Swap Meet | 2 | 11th July 2007 01:10 PM |
| Poindexter's 6v6 PP amp | Cassiel | Tubes / Valves | 34 | 10th October 2005 02:56 AM |
