purpose and value importance of resistor
Old 10th April 2012, 07:46 PM   #1
CoolJazz is offline CoolJazz  Netherlands
Default purpose and value importance of resistor
I'm building a phono stage and I have question about a couple of resistors and their values.
The parts list states that r1 should be 2m2 ohms and r2 and r3 should be 1m2 ohms.
I ordered Allen Bradley resistors in these values but they are all quite a bit off.
The 2m2's are all about 2m4 ohms and the 1m2 are all about 1m35 ohms.
Now for my question, what is the purpose of these resistors in the circuit and how critical are their values?
Would it be ok to use the one's I have or should I get some more accurate?
Tnx
Cj
Old 10th April 2012, 07:57 PM   #2
Shoog is offline Shoog
Shoog's Avatar
Neither valve is that critical but the quoted values seem excessively high in my opinion. Having such high values will tend to make the circuit noisy. 100K seems more appropriate.
Shoog
Old 10th April 2012, 07:59 PM   #3
tomchr is offline tomchr  Canada
tomchr's Avatar
Just to be completely pedantic... It should be 2M2 and 1M2. M = Mega (1e6); m = milli (1e-3). Sorry. Pet peeve of mine.
Now to your question. The tube with its grid connected to R1, R2 looks to be operating as a cascode. It's biased by the resistive divider formed by R1, R2. The capacitor in parallel with R2 decouples the noise of the biasing network to ground.
R3 is the grid leak resistor for the last tube. It prevents tube bias point shifts by ensuring that any grid leakage current is led to ground.
The values of R1, R2, and R3 are not critical. Modern +/-5 % tolerance resistors should work just fine here. I'm sure the circuit would work even with old +/-20 % tolerance carbon composition resistors.
Modern metal film resistors are very good and resistive up past 40 MHz (the limit of my tester). Hence, I don't see any reason to use boutique resistors. But feel free to do so if you feel like it.
I disagree with Shoog's comment about noise. It is true that the thermal noise power spectral density of a resistor is linearly proportional to its resistance. However, all the resistors in question are bypassed by capacitors. This limits the noise bandwidth. Going through the math, you'll end up with en = k*T/C (en = noise power spectral density (V/rt(Hz)), k = Boltzman's Constant (1.38E-23 J/K), T = absolute temperature (K), C = capacitance (F). So the noise is actually independent of the resistor value.
~Tom
Modulus-686: 240W/8Ω @ <0.00025% THD. Modulus-86: 40W/8Ω @ 0.000054% THD. DG300B & Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 11th April 2012, 12:13 AM   #4
roline is offline roline  United States
roline's Avatar
What about the wattage and current density through the medium, any effect on noise?
SO many tubes, SO little time!!!
Old 11th April 2012, 12:54 AM   #5
tomchr's Avatar
Resistors exhibit Johnson noise aka thermal noise.
Thermal noise: en = 4*k*T*R
k = Boltzman's constant
T = absolute temperature (deg K)
R = resistance in Ohm
en = noise power spectral density (V/sqrt(Hz))
Thermal noise is white (uniformly distributed in frequency).
In addition, carbon composition types exhibit 1/f or "popcorn" noise. I.e. the noise is higher at lower frequencies.
There's also a term called "excess noise" which, to my knowledge, refers to noise not accounted for in thermal noise. I don't know if this excess noise is voltage dependent. I've seen it listed in resistor datasheets, so if you want to know, I suggest looking there.
I'm not aware of any noise type that would depend on the current density in the resistor. The only current-dependent noise types I know of relate to the flow of carriers across a semiconductor junction. There are no semiconductor junctions in a resistor.
~Tom
Old 11th April 2012, 10:42 AM   #6
DF96 is offline DF96  England
As tomchr says, the resistors are bypassed (R1,2) or connected to lower impedances (R3) so their noise should not be a problem. Noise from other resistors (e.g. anode load, RIAA network) will be more important.
The exact value of R1 and R2 does not matter; it is their ratio which sets the grid voltage for the upper valve. The value of R3 will have a small effect on the LF response of the RIAA network, depending on the network impedance.
Old 11th April 2012, 06:41 PM   #7
Chris Hornbeck is offline Chris Hornbeck  United States
Chris Hornbeck's Avatar
This is all correct per modern usage. Excess noise includes all noises not accounted for by either thermal/Johnson/Nyquist noise or shot noise (current dependent noise across a potential difference), and includes popcorn, 1/f and other process-dependent noises.
There's a lot of confusion about these nowdays because older texts, RDH4 ("the big red bible") in particular, used "shot noise" to mean the thermal noise within electron valves. Causes no end of confusion these days. And "excess noise" was just as mysterious then as now!
Thanks,
Chris
Old 11th April 2012, 06:48 PM   #8
tomchr's Avatar
I'm not clear on how shot noise would show up in resistors, though. There shouldn't be any potential barriers, only a linear decrease in potential across the resistor. At least in the ideal world. Do potential differences arise due to work function differences between the end caps and the resistive film material? Trying to learn here...
~Tom
Old 11th April 2012, 06:58 PM   #9
Shot noise shouldn't appear in resistors. I didn't mean to imply that, but maybe my poor wording included it. There may be some folks in the world that understand the fine line between potential differences in the separate components of a resistor and the whole resistor, and can parse the measurable differences of real-world resistors, but they don't include me. Carbon comp resistors are often described as a stack of granules, giving one pause, but I wonder how realistic that is.
My post was really just to affirm your choice of terms. Old usages cause lots of current confusion.
Thanks,
Chris
Old 11th April 2012, 08:25 PM   #10
Silly me expecting a simple answer
Thank all you people for the info, I used the resistors i mentioned and all the checks are pretty close to what they should be. Thanks for the explanation on the function of the resistors
carry on
Cj
purpose and value importance of resistorHide this!Advertise here!
Importance of resistor working voltage spec? leadbelly Parts 15 20th July 2014 03:13 AM
Importance of layout robmil Solid State 8 12th April 2011 07:09 PM
Purpose of series input resistor in guitar preamp? miallen Instruments and Amps 14 17th December 2010 10:42 AM
The Importance of Being Biased Nelson Pass Pass Labs 74 26th July 2007 01:58 PM
Importance of Cap/Resistor type Dwiel Chip Amps 0 13th December 2004 08:01 PM
