Help with amp please.
Old 10th April 2012, 03:50 PM   #1
kendt is offline kendt  Canada
Default Help with amp please.
I have a pair of approx 95db spkrs. I will be running 4 channels of t amp to the bass drivers through a mini dsp. I am looking for a nice tube amp to handle the midrange duties with the full range drivers. I would like some suggestions for a nice sounding but simple to build amp. I would only need a few watts.
Old 11th April 2012, 02:15 AM   #2
Eli Duttman is offline Eli Duttman  United States
A triode wired "El Cheapo" will give approx. 6 WPC. As deep bass extension is truly a non-issue, you could save a few $ by using Edcor's GXPP15-n-8K, where n is the voice coil impedance.
From your description, you might be able to eliminate the volume controls.
Eli D.
Old 11th April 2012, 12:35 PM   #3
Well thank you. that is very interesting. I haven't seen that one. It sounds perfect.
Old 11th April 2012, 02:41 PM   #4
TheGimp is offline TheGimp  United States
TheGimp's Avatar
That should be an excellent amp for your system. I have a 6P1P (soviet equivalent to 6AQ5) PP amp in similar configuration driving a set of 96dB/W-M speakers and it is more than adequate.
Help with amp please.Hide this!Advertise here!
FS- Twisted Pear Buffalo 32S Board & System New & Unused secretriches Swap Meet 1 10th August 2009 03:17 PM
Modify & build out (2) Western Electric 300B / 2A3 Hammond monoblock amps & UTC LS-5 quality sound Tubes / Valves 0 9th May 2009 04:59 PM
Krell KSA 80 bias & dc offset check & adjust procedure Clouseaupte Solid State 3 9th August 2007 10:39 AM
DIY-AMP <ZAS> Low THD & IM high bandwith murphy Solid State 18 30th December 2005 11:28 AM
