Determing the reason for mystery? cap in schematic.
Old 10th April 2012, 07:34 AM   #11
devilsindetails is offline devilsindetails  Canada
devilsindetails's Avatar
Originally Posted by Bibliophile View Post
If you have a multimeter, measure between control grid an ground.
Normally you will see 0 Volts. If it is even a little positive, you could have a leaky coupling cap from the driver. What sort of caps did you use ?
OS Sprague Wax Caps, same voltage rating rating and value, but I guess there`s always a chance one of them is not quite up to snuff.
Excuse my inexperience but which pin is the control grid...
"A problem left to itself dries up or goes rotten. But fertilize a problem with a solution--you'll hatch out dozens." (N.F.Simpson)
Old 10th April 2012, 07:37 AM   #12
Bibliophile is offline Bibliophile  Australia
Waxed paper caps were notorious in the past for developing leakage as they aged. Some will disagree but I would use polyester. Control grid is pin 2.
Old 10th April 2012, 07:42 AM   #13
Point well taken...I should be utilizing known good caps...however I used what I had on hand and superficially looked A-OK...how far above the original Uf value can I use safely...I`ve been told no more than 10%...I know I can use higher voltage rated caps (just not lower).
Old 10th April 2012, 07:45 AM   #14
Thanks on the control grid pin...I had looked at pin-out for the EL84 and noticed that it showed g1 and g2.
Old 10th April 2012, 07:49 AM   #15
Depends on the value of the capacitor and the resistor between control grid and ground or more precisely the time constant of the two. To high on either one can lead to an effect called grid blocking or blocking distortion.
See an explanation here: Blocking Distortion
G2 is called screen grid.
I'm going off line now so I can't respond to any more questions until tomorrow but there are plenty of more qualified people than I here who can help you out.
Cheers for now.
Old 10th April 2012, 07:55 AM   #16
OK..thanks so much for your time and courtesy Bibliophile...I can see I have my reading cut out for me...I`think I`ll stick with exact values for the caps for now but ensure they are known good and will try the poly`s as I`ve heard good things about them....Leon
Old 11th April 2012, 11:05 PM   #17
Thanks for the kind words.
I will be away for several days.
Cheers
Old 12th April 2012, 09:55 AM   #18
DF96 is offline DF96  England
The capacitor ringed in green is for 'tone correction' i.e. HF rolloff. Very common in old radio circuits, as people in the 1950s were not used to hearing much treble. In effect, it lowers the OPT HF resonance frequency. In essence, you have a pair of radio receiver audio stages.
Old 12th April 2012, 12:47 PM   #19
Thanks for the input DF...now as this amplifier had a separate pre-amp/radio chassis with treble and bass pots (which I simply removed from the equation) would I be better advised to remove this particular capacitor to restore (raise) OPT HF resonance?
I intend to use this amplifier with only a volume pot and no frequency compensation.
Old 12th April 2012, 05:31 PM   #20
Probably best to experiment. Treat the capacitor as a fixed treble tone control.
Determing the reason for mystery? cap in schematic.Hide this!Advertise here!
Determing heatsink CorySCline Chip Amps 12 7th September 2011 05:09 PM
Determing current dump from output transistors Arroyo Solid State 3 10th June 2011 01:19 AM
That mystery trem cap jjman Instruments and Amps 6 5th April 2011 12:47 AM
Vote and reason why, can a Cap improve, be a band aid or a waste of Farad? mikee55 Car Audio 12 26th October 2010 01:54 AM
determing speaker power philspeed Multi-Way 0 30th April 2006 11:50 PM
