fluctating bias
fluctating bias
Old 9th April 2012, 05:21 PM   #1
Rlg is offline Rlg  United States
Default fluctating bias
Hi all,
I am new here and can't find anything related to my problem in the archives. I have a pair of Thor TPA 60 mono block amps. Tubes are 4 el34/kt77 1-12at7, 1-12au7, 1-12bh7a. One amp has had a problem of occasionally, when driven fairly hard the bias starts to fluctuate rapidly on all 4 tubes. It will swing from 30 to 600ma. I lowered the bias from 240mv to 220mv and the problem stoppd for a while. Now it does this with bias pots all the way down and no signal after about 2 minutes of being turned on. I have also had a problem with the same amp causing the woofer in my speaker to randomly move in and out without music being played. This does not happen in the other amp. I have sent this amp into Thor twice. The first time they replaced a bias control on V2 the 12au7, then the second time a relay on the power input. It worked fine for several months and now is back to where it was before. V2 seems to be where my problem is. I had a rushing sound over the weekend and it changed or went away when I would wiggle V2. I thought I had a bad tube but after changing it the bias started this rapid fluctuation again. The tube rushing sound did stop though. Any ideas?
Thanks,
Russ
Old 9th April 2012, 10:10 PM   #2
DF96 is offline DF96  England
Motorboating? Possibly capacitor failure. Maybe the amp has marginal LF loop stability?
Old 11th April 2012, 09:19 PM   #3
alex5612 is offline alex5612  Austria
Poor Output tubes could be the cause as well, especially if they're running at high Pa and/or high Rg.
Swap the output tubes between the channels and re-adjust bias. If you can track down the problem to a specific set of tubes please have them checked with a tube-tester, because each time the anode current skyrockets the tubes are overloaded and even if they're still good they will wear prematurely. The question remaining is if the tubes are experiencing thermal runaway under normal operating conditions or if there is an error like a bad -ug1 pot in the amplifier.
Old 11th April 2012, 11:29 PM   #4
godfrey is offline godfrey  South Africa
Originally Posted by Rlg View Post
rushing sound...
may be a symptom of high frequency oscillation.
Old 12th April 2012, 11:32 PM   #5
bobrown14 is offline bobrown14  United States
First thing I'd be checking is all the usual suspects. Be sure your speaker posts are tight specially the grounds, and check all resistor values and check the star ground and be SURE it's tight and look for any oxidation on the ground points. Be sure the caps are discharged, 400V on a cap can get REAL painful or worse. Weird things can happen even if one of the speaker posts are loose. Start with the obvious little things first specially since it's been in for service. I would think the service folks tested the tubes... but you can never assume anything.
Connectors look good, grounds are tight, resistor values good, clean the switches and pots, then look to the caps and test them as well (discharge first with a high value 10W or so resistor and do it twice) then test the caps. One hand in your pocket and be fresh. You sound like you MAY know what you are doing but there's killer voltage there even with the amp turned off. You wouldn't want to find your bleeder resistor took a dump. Best to just bleed the voltage from the caps first before poking around.
Bob
Old 13th April 2012, 05:19 PM   #6
PlasticIsGood is offline PlasticIsGood  United Kingdom
PlasticIsGood's Avatar
Hi all,
I don't see the meaning of "240mv to 220mv". Is this read across a current sensing resistor? Is there one per valve or is this reading for the sum of all? Do you mean that each and every valve is fluctuating, or the sum?
Anyway, it would be good to measure the actual bias voltage (Vgk). If it is also fluctuating then you might investigate whether this is caused by grid leakage, coupling cap leakage, or by a fault in the bias circuit. If it is not fluctuating then the fault must be with the valve, or possibly with its load.
Without a circuit diagram, "all the way down" could mean anything, depending on the range of adjustment available.
If the problem arises after a while, regardless of bias setting, then you should look at and around whatever gets hot in that time. That would include all parts of the bias circuit, components attached to the valve base, and the power transformer heater and bias windings.
If the only problem is a repeatedly failing bias circuit, then it's likely that some components are incorrectly specified. Also, bias circuits should generally fail safe, so perhaps a better circuit is needed.
Need a diagram, obviously. Failed cathode resistor or its bypass cap, likely if they are attached to the valve base because they get hot. Valve could fail in consequence, and then a new valve solves one problem but not the other, like changing a fuse without rectifying the cause.
What's the link between all these problems? Is the amp direct coupled? Or are some coupling caps suspect too?
Ian
Old 13th April 2012, 09:29 PM   #7
Thanks to everyone who replied.
I am in way over my head here. What I do know is it is not motorboating. I tried a 3rd quad of el34 tubes and the flucuations started almost immediatly as the amp was warming up.
All connections are good. Tube sockets were replaced by the tech before I ever bought the amp. Everything inside and out is tight.
Plasticisgood: The amp has a built in LED meter to read the bias on each of the 4 tubes. Flipping a switch shunts the input to ground and allows me to read and adjust the bias on each tube individually. With all pots turned down I got the following readings from left to right 0.68, 0.97, 115, 140. If I switch the tubes around the value of that tube pretty much stays the same without regard to what position it is in. I am attempting to add some pics of when the amp was rebuilt. I don't have schematics but could possibly get them from the tech.
This amp has completely new boards installed by the new owner of the company. It is the only pair of amps with this new board and they installed most of the old components on to it. I don't know the age of the amps but probably only 6 to 8 years.
Maybe my question should be does anyone know a good tech near Iowa?
Old 14th April 2012, 10:09 PM   #8
nazaroo is offline nazaroo  Canada
Banned
The pots for adjusting bias could be burning out, or gone 'open circuit'.
Such circuits really should have safety resistors around them so that if a pot opens up there is still a reasonable bias on the tube.
Hard to check the design without a schematic.
Old 14th April 2012, 10:28 PM   #9
How do you know it is not motorboating? Fluctuations in cathode current cannot happen until the output valves have warmed up. By then motorboating is possible. Bias instability is another possibility, as is RF parasitic oscillation. Bias problems would tend to stick to a socket, but RF problems might (sometimes) follow the valve around. Does the amp have grid stoppers?
We are still working in the dark. Do you have a circuit diagram?
Old 26th April 2012, 07:37 PM   #10
Thanks to all who chimed in on this problem. I wasn't able to get a circuit diagram, so out of frustration I sent it off to be repaired.
fluctating biasHide this!Advertise here!
Dynamic Bias - Active Bias - Automatic/Self biased - Overview wanted tiefbassuebertr Pass Labs 20 14th April 2018 01:45 AM
Changing grid leak bias preamp to cathode bias bereanbill Tubes / Valves 8 28th March 2009 05:26 PM
Bias problem- 1 Socket shows extremely low bias! otokomae Tubes / Valves 12 31st December 2008 10:01 PM
Stray hum pickup *preamp* cathode R-bias vs. battery bias & 12AU7vs.5687 awedio Tubes / Valves 2 19th April 2008 01:30 AM
Supressed bias amplifier, automatic variable bias system. destroyer X Solid State 2 20th September 2004 10:24 AM
