LED's in the cathode..
Old 9th April 2012, 05:19 PM   #11
yagoolar is offline yagoolar  Poland
yagoolar's Avatar
Send a message via ICQ to yagoolar LED's in the cathode..
I have used LED matrix in my SE amp based on 6B4G equivalent (Russian 6C4C) replacing RC bias. The sonic difference is huge and clearly audible. My first try was SY's RLD. Now there is ongoing push-pull project with LEDs.
Oh, pardon me. You asked about *pre* stages.
Old 9th April 2012, 05:30 PM   #12
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Originally Posted by dgta View Post
Osvaldo, the LEDs are used in the cathode, for bias. Not in the anode.
ANODE CURRENT IS THE SAME AS CATHODE CURRENT (except in grid leak), so if the cathode current is distorted, the anode also will be, and there, the anode AC voltage to ground will be also distorted.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 9th April 2012, 05:43 PM   #13
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
Here's the thread, TheGimp, posting #33.
Best regards!
Old 9th April 2012, 05:51 PM   #14
On Hiatus
SY's Avatar
And yet, experimentally the distortion of circuits using LED bias is quite low (assuming competent design). My phono preamp, for example, has 0.03% distortion at full output, almost entirely second harmonic, with no harmonics detectable past third, and it uses LED bias for two of the three amplification stages.
If you think about the actual AC impedance, how it varies over the current swing of the stage, and the effect on circuit operation, it becomes more evident why the cathode LED is not a significant source of non-linearity.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 9th April 2012, 05:54 PM   #15
M Gregg is offline M Gregg  England
SY,
Do you have any thoughts on the effect of LED cathode bias in preamp tubes with CCS or Gyrator anode load?
Just an observation OK the circuit I describe should have a cap across the cathode load to prevent drift however here is a tail...I used resistive load in place of a ccs with no cathode bypass cap.. the volume of the amp altered with the increase in temp over about an hour (on its own). Replaced the resistor on the cathode with an LED and 1N4148 for the set point..Guess what no drift..and better drive from the stage..
M. Gregg
Old 9th April 2012, 06:04 PM   #16
On Hiatus
SY's Avatar
Since that's what I do in most of my designs, I'm clearly in favor. Take a look at His Master's Noise to see one implementation.
Old 9th April 2012, 06:20 PM   #17
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
Yes the anode and cathode currents are essentially equal, otherwise the split load PI wouldn't work. The difference is that a tiny voltage change on the anode wouldn't be noticed. A tiny voltage change on the cathode will affect the bias on the tube causing a bigger than normal change in current through the tube.
And yet, experimentally the distortion of circuits using LED bias is quite low (assuming competent design)......The LED acts as a constant voltage source. Or close to it, depending on the particular LED's dynamic impedance. Whether it's appropriate and of benefit for any given stage depends on the design.
I have also noticed some very low distortion readings in LED biased stages. Replacing the LED with a resistor and cap adjusted for the same operating conditions did not yield the same low distortion. Adding a bypass cap across the LED actually increased the distortion. The LED improvement varies with the LED and the tube being used, even among batches of inentical LEDs and tubes. The tubes were CCS loaded 12AT7's and the LED's were from a bag of 1000 surplus green LED's.
it is my belief that the nonlinearities in the 12AT7's and the LED's were cancelling to some extent, but I have not tried to prove this theory yet.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 9th April 2012, 06:24 PM   #18
tomchr is offline tomchr  Canada
tomchr's Avatar
For the lowest THD in a triode input stage, I use a constant current source on the anode and LEDs in the cathode. For best results use LEDs with a low dynamic impedance. The red and green ones seem to be the best with a dynamic resistance under 10 ohm in most cases.
I have verified my claims that the lowest THD is obtainable with a CCS and LED biasing using an HP 8903A distortion analyzer. I have verified this with several triodes - 6J5, 5842, d3A, to name a few.
I realize that for some, this may be too much sand in the glass, but ultimately it comes down to your design goals. For me, the goal is to achieve the best sound quality.
~Tom
Modulus-686: 240W/8Ω @ <0.00025% THD. Modulus-86: 40W/8Ω @ 0.000054% THD. DG300B & Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 9th April 2012, 06:30 PM   #19
mogliaa is offline mogliaa  United Kingdom
mogliaa's Avatar
I personally achieved great results on a 6j5 driver with a Mu-follower gyrator achieving less distortion than CCS and very happy with sound, of course: LED bias
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp)
http://www.bartola.co.uk/valves/
Old 9th April 2012, 06:34 PM   #20
Looks like another stage of LED bias testing on the cards..
Just got to crack the gyrator set up....
One other thing I did notice was how much better a range of CD's and material sounded with the LED bias...some being harsh on some systems..
M. Gregg
LED's in the cathode..Hide this!Advertise here!
LED's jim5763 Swap Meet 3 21st February 2010 01:04 AM
300B Cathode Feedback + Cathode Bias korneluk Tubes / Valves 13 7th January 2009 08:07 PM
UL to triode mode conversion on cathode bias amp-different cathode resistors needed? bigwill Tubes / Valves 6 30th December 2007 12:37 AM
