LED's in the cathode..
Old 16th October 2012, 04:30 AM   #91
Pano is offline Pano  United States
Pano's Avatar
No cap needed on the LED. I did leave out the bias cap on the Pentode.
In my app I'm pulling about 6mA thru a red LED (1.75V)
Old 16th October 2012, 04:31 AM   #92
mooreamps is offline mooreamps  United States
Originally Posted by Bigun View Post
Is one of the parts you left out a capacitor ? just wondering if without a bypass capacitor you are now going to have a.c. across the diode. And we know what that means...
Yes, you do get AC thru a forward biased diode..
No bypass cap required...
-very respectfully;
-gary
Old 16th October 2012, 04:40 AM   #93
Pano's Avatar
I thought (for 3 seconds) "Do I want a bypass cap on the resistor below the LED?"
Duh, no! Who knows why?
Old 16th October 2012, 04:58 AM   #94
dgta is offline dgta  United States
Never mind...
Old 3rd November 2012, 08:18 PM   #95
DrewP is offline DrewP
Has anyone ever set up a concertina / split load phase inverter with LED bias?
With a 300v B+ I'm planning to use a 6CG7 with 22k at anode. Grid has 470k coming off it that joins the bottom of a string of 3 red LED's under the cathode, followed by the second 22k to ground. The 2 signal feeds to the output tubes comes from anode and from below the 3 LED's respectively.
Any of the LED users see a reason as to why this won't work?
Old 3rd November 2012, 08:23 PM   #96
tvrgeek is offline tvrgeek  United States
One of these days I need to quit building speakers and finish my RLD. It is a modified Meng P61, which is no longer a P61 anyway. I keep meaning to build some really efficient speakers but my brief adventures with full range drivers sent me back to traditional inefficient multi-way speakers totally unsuitable for a 7 W amp.
Old 3rd November 2012, 08:41 PM   #97
Doug R is offline Doug R  United States
Hi Guys,
I have what is very likely a dumb/newb question, can you parallel a resistor + LED(s) instead of a resistor + cap in the cathode (since AC can pass through the LED)?
Doug
Old 3rd November 2012, 09:47 PM   #98
DF96 is offline DF96  England
With an LED, what is the parallel resistor for?
Old 3rd November 2012, 10:15 PM   #99
Well, as I said, it's a naive question, but I have just been wondering if one could reasonably use LEDs when the cathode sits at a pretty high voltage, i.e. 70v for a 300b.
Doug
Old 3rd November 2012, 10:31 PM   #100
Merlinb is offline Merlinb  United Kingdom
Merlinb's Avatar
Yes, no problem with that.
LED's in the cathode..Hide this!Advertise here!
LED's jim5763 Swap Meet 3 21st February 2010 02:04 AM
300B Cathode Feedback + Cathode Bias korneluk Tubes / Valves 13 7th January 2009 09:07 PM
UL to triode mode conversion on cathode bias amp-different cathode resistors needed? bigwill Tubes / Valves 6 30th December 2007 01:37 AM
