Heater supply
Heater supply
Old 9th April 2012, 07:26 AM   #11
Navyblue is offline Navyblue  Singapore
Thanks Thomas.
My B+ is 100V, so I guess I'd use something like 100k and 25k.
Old 9th April 2012, 07:30 AM   #12
Vinylsavor is offline Vinylsavor  Germany
Vinylsavor's Avatar
Hi!
Then rather use something like 33k and 10k. Most tubes have a max impedance of 20k spec'ed between heater and cathode. Use 2Watt types or higher
Best regards
Thomas
http://vinylsavor.blogspot.com/
Old 9th April 2012, 07:55 AM   #13
Sure, would do.
Thanks.
Old 14th April 2012, 05:02 PM   #14
Another question.
So I got myself a 6-0-6V transformer (12V CT, not dual secondary). When I use one side of the 6V for the amplifier tube heater and bias it wit B+ as said earlier, can I still tie the cathode of the rectifier tube with the heater with the other side of 6V?
Should I not connect the cathode to the heater on the rectifier tube, since both the heater of the amplifier tube and the rectifier tube is connected through the transformer?
Is it even a good idea to share a transformer like that?
Thanks.
Old 14th April 2012, 05:27 PM   #15
DF96 is offline DF96  England
Why use an EZ81 for 20mA? EZ80 would be a better fit, and use less heater current. Or EZ90/6X4. For 20mA you could almost use an EB91!!
Old 14th April 2012, 07:44 PM   #16
I am no expert, compared to EZ80, it seems that EZ81 is more widely available? And it's still in production. As for the current, I meant to say 20mA per channel (so 40mA total), and I would like to keep the option of bumping it to 40mA per channel.
Old 14th April 2012, 08:06 PM   #17
Yes, EZ81 is still in production. Both are widely available in NOS form.
Old 14th April 2012, 08:44 PM   #18
pauldune is offline pauldune  Netherlands
pauldune's Avatar
Am I missing something? If you rectify 6v and buffer with a cap, your voltage will be round 7v, so normally you'll need even less then 6v.
Paul
Old 15th April 2012, 05:51 AM   #19
theorganeer is offline theorganeer  United States
You are right, if you bridge rectify and filter 6VAC or 6.3VAC you'll end up with 8.4 to 9VDC unloaded. And that will drop as you increase the number of filaments. So it has to be regulated. But the problem with using the LM317 is that it needs at least 1.5V of headroom so it is likely to drop out. And it's limited to 1.5A or so. So using only 6VAC input isn't safe except for low heater currents. I've had good success with the MIC29750-5.0 regulator (digikey has it) and two 1N914 diodes on the reference pin. Since it is a low dropout regulator, it can regulate with only 350mV of headroom, and supply at least 5A. With such a low headroom, you can mount the regulator to the chassis as a simple heatsink (using an insulator).
Old 15th April 2012, 06:31 AM   #20
You guys are not reading the earlier post.
I will be feeding AC to the the heater.
But an unrelated question, supposedly I am feeding DC to the heater, would it still be beneficial to bias the heater?
But please answer my earlier questions.
Thanks.
Heater supplyHide this!Advertise here!
Is this OK for a heater supply? blacklight Tubes / Valves 9 12th December 2006 05:58 PM
Is this heater supply OK? Nuuk Tubes / Valves 39 18th August 2006 11:20 PM
Regulated Heater Supply Kashmire Tubes / Valves 6 4th January 2004 02:23 AM
help with heater supply jarthel Tubes / Valves 5 24th July 2003 01:12 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 01:30 PM
