Re: Tube Line gain stage with pcc88 or ecc82
Old 10th April 2012, 06:28 AM   #21
formula 22 is offline formula 22  El Salvador
formula 22's Avatar
Originally Posted by tinitus View Post
may I ask, why 1Mohm input impedance ?
usually only for musical instruments ?
This question can answer Mr. ruffrecords.
Old 11th April 2012, 12:07 PM   #22
sith is offline sith  Croatia
how bout something like this?
from this site RH 84 - Tube Audio ...... RH DESIGN
there was big thread on this theme here on forum years ago...
Parce mihi, Domine, quia Dalmata sum!!!
Old 13th April 2012, 07:16 AM   #23
formula 22's Avatar
Sith thanks for help!
What voltage should be brought to the A +?
Under what name is called a theme that I find.
thank you and cheers!
Re: Tube Line gain stage with pcc88 or ecc82Hide this!Advertise here!
A Heretical Unity gain line stage SY Tubes / Valves 87 4th October 2015 03:24 AM
Heretical Unity Gain line stage PLUS a little gain ? yagas Tubes / Valves 7 24th January 2006 01:30 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Balanced line stage gain problem ! lykkedk Pass Labs 9 19th June 2003 07:24 PM
