Old 9th April 2012, 05:25 AM   #11
formula 22's Avatar
Originally Posted by ruffrecords View Post
When you say 'output <2.7K ohm' do you mean the load it is driving is 2.7K ohm or you want the output impedance to be < 2.7K ohms?
Cheers
Ian
Output impedance is <2k7
Old 9th April 2012, 06:00 AM   #12
formula 22's Avatar
Hi all!
Is this the schematic can be developed valve line stage preamp with PCC88 or with ECC88 or some are needed changes ?
Here's the comment.
thank you and cheers!
Old 9th April 2012, 06:18 AM   #13
tinitus is offline tinitus  Europe
apart from being more expencive, 6H30 ?
Old 9th April 2012, 06:53 AM   #14
formula 22's Avatar
Either schematic should like this look!?
Old 9th April 2012, 07:21 AM   #15
ehh, is out connected correctly ?
Old 9th April 2012, 07:26 AM   #16
formula 22's Avatar
If the wrong out, please give the proposal.
thank you
P.S.
The output is this of to reduce the gain to 10x
Old 9th April 2012, 07:42 AM   #17
thank you
Im not that clever, sorry
I just thought it looked 'different'
Old 9th April 2012, 01:54 PM   #18
ruffrecords's Avatar
That schematic looks about right to me. Operating point is around 9mA, plate dissipation is under 1 watt. Gain should be close to 10 with that plate load pot divider. Output impedance may be higher than you desire because cathode bias resistor is not bypassed. This increases effective plate resistance from around 3K to about 10K and increases distortion.I would recommend bypassing the cathode resistor.
Cheers
Ian
Ian
Old 10th April 2012, 05:57 AM   #19
formula 22's Avatar
Default modifications
Cheers
Ian
Hi ruffrecords!
The signs of these changes on the cathode you think. Cathode to bypassing the resistor R1 = 220Ohm/0,25W and the electrolytic capacitor C1= 680uF/16V. I think that the anode current is about 11mA?.
This schematic now has as much gain and what is the output Impedance?
What is the gain without the capacitor C1?
Thanks and cheers!
P.S.
If you have another suggestion you name it.
Old 10th April 2012, 06:24 AM   #20
may I ask, why 1Mohm input impedance ?
usually only for musical instruments ?
A Heretical Unity gain line stage SY Tubes / Valves 86 26th April 2013 10:18 AM
Heretical Unity Gain line stage PLUS a little gain ? yagas Tubes / Valves 7 24th January 2006 01:30 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Balanced line stage gain problem ! lykkedk Pass Labs 9 19th June 2003 07:24 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
