Can I delay part of a B supply this way?
Old 8th April 2012, 01:30 AM   #1
Ceglar is offline Ceglar  Australia
Banned
Default Can I delay part of a B supply this way?
I'm needing to delay part of a B supply for a DC coupled amplifier; the input stage plate voltage needs to be at the grid of the second stage before the second stages plate see's any voltage.
Have been using a switch, it works.. but kind of clunky, and the second stage doesnt benefit from any soft start, it just gets 'hit' with 200V.
I'd like to ask if theres any problem that anyone can see with doing it this way. I'm not sure if the diode tube is OK with 260VDC across it, then bring th heater up like this. Any comment is appreciated.
Thanks.
Old 8th April 2012, 01:38 AM   #2
Chris Hornbeck is offline Chris Hornbeck  United States
Chris Hornbeck's Avatar
If the time delay is to be a bi-metal switch like the Amperite's you'll want to keep current through it to the bare minimum. They arc for the last part of their travel and the contacts degrade steadily. Your circuit probably has a pretty low primary current, but keep some spares for the future.
All good fortune,
Chris
Old 8th April 2012, 01:51 AM   #3
HollowState is offline HollowState  United States
HollowState's Avatar
Assuming you're using a solid state bridge rectifier, just the delay of the tube heating up should be long enough without an additional 60 seconds. And a 6087 is an expensive tube to use for this service. There are many other indirectly heated diodes, like damper diodes, to use. Some of them are even slower heating then a 6087. And why heat the filament from the HV side of the bridge?
1944: 18 year olds storm the beach of Normandy into almost certain death.
2017: 18 year olds need a safe place because words hurt their feelings.
Old 8th April 2012, 02:20 AM   #4
Eli Duttman is offline Eli Duttman  United States
Something like a 6AX4 or, if current production is what's wanted, a Russian 6Д22С (6d22s).
Eli D.
Old 8th April 2012, 03:48 AM   #5
Banned
Thanks for all the replies, it seems then that the idea will work fine and the diode will be ok with this service.
The time relay is a DIN rail mount CHNT NTE8-480B rated for 5A at 230vAC, so it will be ok with switching the diode heater xfmr primary.
The supply rectifier is pair of 6CJ3 damper diodes, I was going to use 6087 simply because they are on hand along with heater xfmr and the socket. The diodes heater is energised by a heater transformer, so line voltage to the primary of that. Maybe ok without the timer, but its on hand and the first tube is fed from a split rail supply that takes some time to stabilise.. so just to be safe.
6X4.. nice idea.. I have one here somewhere too.. less heater current and a smaller profile.
Thanks for your help, have a nice weekend.
Old 10th April 2012, 01:54 AM   #6
roline is offline roline  United States
roline's Avatar
12AL5 or 6AL5 are still cheep......
SO many tubes, SO little time!!!
Can I delay part of a B supply this way?Hide this!Advertise here!
F-5 Power Supply part Question Russellc Pass Labs 9 21st July 2010 05:45 PM
Full Modification of CD Transport Audioeca Mephisto - part 1 (Power Supply) pooya Digital Source 6 13th December 2009 07:46 AM
Carlos' snubberized Gainclone Power supply, Part II peranders Chip Amps 77 17th September 2009 10:14 PM
Zen Variations Part 3: regulated supply question Decker Pass Labs 6 4th January 2006 01:25 AM
